Stable vacume reading on carb per cyl?
Old Jul 13, 2007 | 01:15 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Default Stable vacume reading on carb per cyl?
I have just bought a mega jolt mappable ignition system for my carbed zetec
It has a map sensor built in and was wondering having 4 carbs, thus 4 vacume pipes, If I link all these together will I get a stable enough reading?
Or should I pipe them into some sort or accumulator / mini chamber like a soda stream bottle, to try and dampen the pulses
Cheers Bri.
Old Jul 13, 2007 | 01:25 PM
AlexF's Avatar
AlexF
I could tell you.... but I don't recall selling it to you
Oh alright...
Interconnecting the cylinders is a good idea - as is restircting the diameter of the pipe leading into the sensor
Old Jul 13, 2007 | 05:09 PM
lawnsy's Avatar
lawnsy
you need some bike carb balanceing gauges....they are used to adjust the linkage to all 4 carbs so they open at exactly the same time and are good for finding probs ........
they have little inline screw valves to dampen the pulse so you get a steady reading
Old Jul 13, 2007 | 05:14 PM
lawnsy's Avatar
lawnsy
these are like mine.........
http://www.busters-accessories.co.uk...l.asp?prod=EVG
Old Jul 16, 2007 | 11:00 AM
AlexF's Avatar
AlexF
They will sync the air flow through each carb - but will do nothing about stabalising the vaccum itself....
Alex
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
