What antifreeze/coolant???
Old Jul 12, 2007 | 10:08 PM
smudge_lad's Avatar
smudge_lad
Default What antifreeze/coolant???
As title....
Just replaced the radiator, so it's needing a fill up before I get her going again. It's a 1.6 CVH EFi turbo
What to people recommend??
Keir
Old Jul 13, 2007 | 11:29 AM
ballin's Avatar
ballin
any mate
Old Jul 13, 2007 | 11:39 AM
nilrem's Avatar
nilrem
STOP!... Carry on
yeh... just dont mix them... either get red, or blue... then remember what you put in!!
Old Jul 13, 2007 | 12:08 PM
iansoutham's Avatar
iansoutham
OCD Victim
I normally run the Ford SuperPlus4 in my motors, generally with a bottle of Water Wetter as well. Really keeps the system cool and works fine.
Old Jul 13, 2007 | 06:57 PM
Šhatter Box's Avatar
Šhatter Box
yep i run fords in mine its better then the halfords shit
Old Jul 13, 2007 | 07:06 PM
Stu.H's Avatar
Stu.H
Get blue!!!
Bluecol or similar
The red stuff is newer and can perish the seals or pipes (cant remember what Karl said LOL)
But blue is the colour to go for (any make really, all comes from same place)
Old Jul 13, 2007 | 07:13 PM
rapidcossie's Avatar
rapidcossie
anti freeze is anti freeze really, I have used tons and tons of diff types from Tescos to Mobil and they all perform similary.
I mix 50/50 with water.
Old Jul 13, 2007 | 09:50 PM
iansoutham's Avatar
iansoutham
OCD Victim
Originally Posted by Stu.H
Get blue!!!
Bluecol or similar
The Red and Blue cannot be interchanged as they will coagulate.
The Blue was designed for old cast-iron engines, like Pintos, Cross-flow, etc... where as the Red was designed for the later alloy-based engines. The CVH has an alloy head and using the Blue antifreeze does everntually cause headgasket erosion around the water ports due to corrosion and around the thermostat housing. I have used the later Ford SuperPlus4 anti-freeze (which is actually compatible with Blue and Red antifreeze due to its composite make-up) and after 3 years, the alloy was still in almost immaculate condition around the thermostat housing When I stripped the engine (after bending some valves @ far too high rpm) the cylinder head water port erosion was almost minimal.
No, antifreeze is not just antifreeze. If it was, then Jap. and some French manufacturers would not have green antifreeze and you would not have to use G12 in VW and Audi cars.
pani_k
Jun 23, 2008 03:59 PM
