amal valve pipe
Old Jul 12, 2007 | 03:47 PM
rs_cabby's Avatar
rs_cabby
Default amal valve pipe
ok probably a stupid question but does anybody know
what the pipe from the amal valve to the metering head
actually does and if it needs this pipe for any reason.
i am asking because my car has 2 bleed valves fitted,
one is replacing the amal valve so is just working as a t-piece
basically and the other is doing its job but i would like
to do away with both of them and just run the pipe straight
from the actuator to the turbo.
thanks
Old Jul 12, 2007 | 06:56 PM
SteveB's Avatar
SteveB
The air is bled off via the amal valve returns back into the intake system, not actually required tho
Old Jul 13, 2007 | 05:34 AM
rs_cabby's Avatar
rs_cabby
ok thanks, so i could do away with the bleed valves,
block off the one to the metering head and
just pipe actuator straight to turbo?
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
mpilk
Sep 27, 2015 09:21 AM
