Dim dip not working...
...any ideas how I should start to try and fix it?
Never had it play up in any car before, no idea where to start
sidelights/parking lights (the 5W ones) come on as normal, as do the dipped and main beams, but no sign of the dim dip when ignition is on.
Its an H plate Mk4 Escort so should have it.
That's not the way it works!
Somekind of low voltage is applied to the main 55 watt bulbs so they glow when on the sidelight setting alongside the 5 watt bulbs. And as above all other functions are ok.
Originally Posted by Shings
stalk will prob be faulty- common thing on the mk3 and 4.
THey're not the same stalk though
Have you had a faulty dim dip due to a stalk before?
You need to check the sidelight and ignition feed to the dim dip relay first.
If these are ok and it(relay) is getting power and earth it is your dim dip relay.
The stalks do play up but you are getting lights on headlight switch setting so is not this.
Try the brown and white relays at the back of your fusebox on the right. They become corroded over time and a bit of sandpaper should fix it.
(Had the same problem on mine, and was told this on the rsoc. worked perfectly afterwrds.
YES- otherwise I wouldn't have suggested it.
I have experienced this problem - stalk related on:
Mk3 escort RS1600i
MK4 escort RST x2
If you're going to rubbish peoples suggestions and your clearly know enough about the lighting wiring system anyway - what was the point of the post?
i know you have said you have checked the relays
but try wiggling them
either 2 little brown or white relays at the back of teh fuse box
which is the main problems
if not then its either stalk or bulbs
Mk3 escort RS1600i
MK4 escort RST x2
I didn't rubbish your suggestions... I was merely trying to get more info out of you in the quest of finding out the best way to sort my car.
I'm hardly going to run off and buy a stalk just because you post a single sentance relpy with no explanation to backup the suggestion.
Anyway, what RS1600i ever had a dim dip function?!
Paul Eggleton
Dec 7, 2003 05:08 PM
