How much boost T34 .63
Just done a top end rebuild and purchased a new turbo - T34 with .63 exh. I have also upgraded to greens with a 3 bar -31 etc and added group a head gasket, cometic gaskets throughout, new oil pump, group A fuel pump, new filter and sec monitor to keep an eye on things
My question is how much boost can i run bearing in mind im still running standard compression. Running 21 at the moment but would like to know whats the safe limit
CheeRS
CheeRS
PassionFords Creator
CheeRS
CheeRS
CheeRS
CheeRS
Russ Payne
Sep 25, 2015 08:29 PM
