atb diff
Old Jul 10, 2007 | 07:17 PM
wide ka's Avatar
wide ka
Default atb diff
im thinking about fitting a quaife atb diff in my car, but just wandering if it would put any other stresses on the rest of the gearbox, shafts, and cv's, thanks alastair
Old Jul 10, 2007 | 07:21 PM
JonnyBravo's Avatar
JonnyBravo
I can't imagine it would be a problem tbh
What car is it ?
Obviously when engaged (which it is only when loaded up) you are putting equal stress on the shafts and cv's but I never had a problem with the one in my nova and tbh I don't know of anyone who has had either.
Well worth the money IMO and if it is a fwd car then probably the best thing money can buy
Old Jul 10, 2007 | 07:27 PM
wide ka's Avatar
wide ka
its a ford ka, with a 1600 zetec engine in, around 180bhp, just worrid it would damage the other weaker parts, does it give worse torque steer?
Old Jul 10, 2007 | 07:34 PM
JonnyBravo's Avatar
JonnyBravo
A little but you do get used to it. You will find it much much tighter in the bends.
Obviously as mine had lead weight over thr front wheels it had a tendancy to plough straight on in the corners if entered too quickly.
The ATB transformed it, as long as your on the power it will get round nearly any corner giving maximum grip, if your off the power then it does get a little loose.
You wont take long to adjust to it and you will soon find nicer lines through corners
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
`spotty
Sep 25, 2015 11:41 PM
