Escort Cosworth opening rear quarter windows
Old Jul 10, 2007 | 09:49 AM
D19 STE's Avatar
D19 STE
Default Escort Cosworth opening rear quarter windows
Has anyone got an exploded diagram of how these bolts and washers go together into the window and hinge
just bought some new bolts, washers etc and not sure how they go together
Maybe anyone with microcat? could help or a ford employee
Pictures stolen off another web site
Steve
Old Jul 10, 2007 | 10:13 AM
redrsmk5's Avatar
redrsmk5
The 2 by the door pillar.....First of all the rubber ring goes into the glass then you will have 2 washers that have 4 very small plastic lugs on them they go against the rubber ring on both sides of the glass. On the outer side the captive dome with the threads inside goes through the rubber ring against the washer (use new black caps if you can get some and lightly smear with vaseline). Then on the inside you will have a zinc colour screw that fastens from the inside of the glass into the captive dome.Dont overtighten too much or the plastic washers with lugs can mishape or split. Then once tight enough put the rubber cap over the internal one.
The rear opener is the same except you spin that on rather than using a philips to fasten into the captive dome.
Easy really, just get a mate to help you support the glass
Old Jul 10, 2007 | 10:19 AM
D19 STE's Avatar
D19 STE
Cheers for this mate
Old Jul 10, 2007 | 10:25 AM
redrsmk5's Avatar
redrsmk5
no problem matey!
Another tip incase you are fitting new black caps. I put mine on with ease. Place the new cap onto a car washing sponge with the dome side down and the captive dome onto it so its ready to go in then smack it hard once square on with a rubber mallet or similar,One swift hit and they go straight in otherwise they take fucking ages !!!! Do remember to lightly grease them first as they rot from the inside out.
Good luck
Old Jul 10, 2007 | 10:28 AM
D19 STE's Avatar
D19 STE
no problem matey!
Good luck
Thanks again mate I have heard the caps can be fookers to get on
Old Jul 10, 2007 | 10:45 AM
redrsmk5's Avatar
redrsmk5
you heard correctly, putting them in a sponge also means the outer painted side doesnt get damaged let me know how you get on mate
Old Jul 10, 2007 | 10:49 AM
D19 STE's Avatar
D19 STE
Will let you know not doing them yet as car is getting bits of the body work done on it
Old Nov 7, 2007 | 08:02 AM
D19 STE's Avatar
D19 STE
We finnally got them on and the caps where b@stards
Had to use a F Clamp to fit the caps on
Old Nov 7, 2007 | 10:42 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
F-clamp !!
I fitted the caps first onto the bolt heads (much easier and less of a risk of breaking the glass) then held the caps to stop them turning using suitable tools and protective covering to not damage the cap.
James Porter
Aug 26, 2015 10:51 PM
Vincereese
Aug 16, 2015 06:38 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
paceo
12
Aug 4, 2015 08:50 PM
Old ford
Jul 31, 2015 06:50 AM
