Which Head Gasket ??
Post Miester !
I know this has prob been done a few times, but opions change.
Do i use a Normal Group A one ??
Or do i use a New 3 layer cometic one i originally bought for the saph.
if so, will my head gasket for my 2wd saph fit the escos ?
Ta..
Al..
Ta..
Al..
If your only running power up to 350, then Group A will be more than sufficient so ive told.
and at £70 from Burtons and most other suppliers, id say its a bargain and if you can fit yourself, even better.
Not sure what the comectic one are good for power wise.
But id look at a WRC jobby, will cost you £300ish of your finest pounds, but you pretty know it aint gna fail you. so for peace of mind, id opt for that option.
Mc5506
Oct 5, 2015 09:57 PM
