max boost on a t35
yep i would say 30 psi is deff max. you should have a 360 degree
thrust bearing if your running that amount of boost, dont think it
last to long cranking like that. bet ya 30 psi feels like a good kick int the
ass thou lol.
ass thou lol.
I also have this turbo and it runs 30psi and had no problems and believe
me it gets used, had it on the car 18 months and its not showing any
signs of wear, but i suppose if you abuse any turbo it will end up being
expensive.
A friend of mine had his T34-48 mapped by MSD peaking at 33psi and
tailing of to 28psi so it just goes to show how tough turbos are as long as
they have a good oil supply.
With these relative smallish turbos most mappers will mapp the boost to
drop at high rpm to stop them overspinning themselves and prolonging
the life of the turbo hope this helps
expensive.
it runs @30psi and holds it engine is low comp,bd14's,wrc spec head etc etc live mapped by steve scott 427bhp.. not to worried about turbo life as looking at going t4 or gt35 with stu's als an lc (winter project)
graham
forgot to say 4x4 so l8
graham
i run 30psi with no major problems
if you go GT35 you cant run full ALS only mild, i was speaking to stu about it when mine was up there a GT turbo will take mild ALS and LC but only use it ocasonally, if used all the time it wont last 2 mins
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
