max boost on a t35
whats the max boost possible on a t35 and whats max boost to make it reliable currently running 30psi will it last long?
cheers graham |
yep i would say 30 psi is deff max. you should have a 360 degree
thrust bearing if your running that amount of boost, dont think it last to long cranking like that. bet ya 30 psi feels like a good kick int the ass thou lol. :top: |
I also have this turbo and it runs 30psi and had no problems and believe
me it gets used, had it on the car 18 months and its not showing any signs of wear, but i suppose if you abuse any turbo it will end up being expensive. A friend of mine had his T34-48 mapped by MSD peaking at 33psi and tailing of to 28psi so it just goes to show how tough turbos are as long as they have a good oil supply. With these relative smallish turbos most mappers will mapp the boost to drop at high rpm to stop them overspinning themselves and prolonging the life of the turbo hope this helps :top: |
30 psi held or peak???????
My T34.63 lasted 6 months running 35 psi peak and 28psi held :cry: That was a 360 degree re-build with uprated seals :( Made 406bhp on greys and live mapped L8 :D :top: |
max boost on a t35
it runs @30psi and holds it engine is low comp,bd14's,wrc spec head etc etc live mapped by steve scott 427bhp.. not to worried about turbo life as looking at going t4 or gt35 with stu's als an lc (winter project) :banana: :top:
graham forgot to say 4x4 so l8 |
i run 30psi with no major problems
if you go GT35 you cant run full ALS only mild, i was speaking to stu about it when mine was up there a GT turbo will take mild ALS and LC but only use it ocasonally, if used all the time it wont last 2 mins |
© 2024 MH Sub I, LLC dba Internet Brands
