cosworth oil pressure
Jul 6, 2007 | 07:08 PM
how is it best to measure this? i.e when stone cold and at idle or not? cheers
Jul 6, 2007 | 07:57 PM
need to know what it reads once up to running temp I 'd say!
Jul 6, 2007 | 08:02 PM
Do it when the engine is at running temp, and you have taken it for a good drive, oil pressure will be at its lowest when It is hot, and that is the most important time
Jul 6, 2007 | 08:06 PM
it reads about 50 when hot is this good?
Jul 6, 2007 | 08:08 PM
whats is it ticking over at?and is it red hot at this presure?
jaiscossie
That butches old car??
Jul 6, 2007 | 08:09 PM
Quote:
at what engine speed? if on a standard pump and at running speed that be about right!
ps also depends on what type of oil your using to!
Jul 6, 2007 | 08:54 PM
Quote:
Originally Posted by radiant red
jaiscossie
Yes
Steve.
Jul 6, 2007 | 08:56 PM
yes it is and this was taken at idle
Jul 6, 2007 | 08:58 PM
If that was a hot idle pressure its very good
Mine is 34psi but mine has a oil cooler as well.
Steve.
Jul 6, 2007 | 09:08 PM
as i worry about oil pressure i have a high pressure pump and on cold its 72 psi when hot its 55psi and on tick over when hot its 32psi is this ok
Jul 6, 2007 | 09:15 PM
Quote:
both figures WOULD suggest that the engine's fitted with a high pressure pump as stated and both figures are vg
Jul 6, 2007 | 09:19 PM
thanks for that m8
Jul 7, 2007 | 07:38 AM
seems very good, i have a high presure pump. Runs about 38 psi at idle and around 70 at speed.
original
Apr 28, 2026 05:20 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Adam-M
Aug 26, 2015 05:53 PM
mrmann
Aug 20, 2015 11:24 PM
Aug 14, 2015 07:29 AM
