CVH sump gaskets
Old Jul 6, 2007 | 01:00 PM
haz87's Avatar
haz87
Default CVH sump gaskets
Are the single rubber and 2 piece cork gaskets interchangeable? or are there actually two different cvh sumps
Old Jul 6, 2007 | 01:10 PM
Luca's Avatar
Luca
Lukesville
From what i have experinced they are different - cant tell you exactly which is which but i bought a gasket set from Ford for my Fiesta Turbo asked for cvh gasket and the cork one delivered didnt fit...
So i ordered a rubber one
Be careful when you order - best bet is to take yours off and match it..
When you re-fit it if you use the rubber one use spray glue to stick it on the sump.
then it makes it easy when re-fitting.
Just dont overtighten, nip the bolts up then run up to operating temp check for leaks and then nip up bolts again once.
Old Jul 6, 2007 | 01:11 PM
haz87's Avatar
haz87
Mines a cork one. But cant get it to seal for shite Just wondered if the rubber fitted as there usually a better seal
Old Jul 6, 2007 | 01:17 PM
ballin's Avatar
ballin
cvh sump gaskets are a cnut mate!
Old Jul 6, 2007 | 01:19 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
My advice with the rubber gaskets is DO NOT USE A FORD ONE!!
Old Jul 6, 2007 | 01:24 PM
haz87's Avatar
haz87
are they interchangeable tho,lol
Old Jul 6, 2007 | 02:00 PM
Luca's Avatar
Luca
Lukesville
if its rs turbo i think you can run the rubber one
Old Jul 6, 2007 | 02:04 PM
haz87's Avatar
haz87
xr3i (mfi)
Old Jul 6, 2007 | 02:07 PM
Luca's Avatar
Luca
Lukesville
Im not sure as not worked on one of these - i think your only option is to drop the sump off and then pop to your local motorfactors they will stock the rubber one and you can see if it lines up....
Cant see why it wouldnt but best to try before you buy
Old Jul 6, 2007 | 02:13 PM
twinkle_2k86's Avatar
twinkle_2k86
i had the rubber one on main haz, i couldn`t get the thing to seal, n matter what i did, i torqued it up correctly as well, but oh no, pissed oil out.
if you want it to seal, i would get some gasket sealent and do it that way, only problem is when you take it off, it will leave a right mess to be cleaned up
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Iain Mac
Sep 30, 2015 09:39 PM
youngben
Sep 27, 2015 09:37 PM
