Mechanical Water Temp Boss mounting.....
Old Jul 4, 2007 | 09:06 PM
cfoster's Avatar
cfoster
Default Mechanical Water Temp Boss mounting.....
As above would it be ok to weld the boss for my mechanical water temp gauge directly onto the side of the rad somewhere? If so does it make any difference where on the rad it goes?
Chris
Old Jul 4, 2007 | 09:10 PM
dave cos4x4's Avatar
dave cos4x4
no good on the rad as it will read different temp to what the engine is.
Old Jul 4, 2007 | 09:14 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Had mine welded on the thermostat housing.
Steve
Old Jul 4, 2007 | 09:16 PM
Kelv's Avatar
Kelv
Almost there!
... and my Defi water sensor is in the bottom of the swirl pot.
Old Jul 4, 2007 | 09:17 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Mine is in the top hose, got a proper fitting kit from Burtons.
Steve.
Old Jul 4, 2007 | 09:28 PM
rapidcossie's Avatar
rapidcossie
My SPA one is in the original temp sender hole in the head
I also have a back up in the top rad hose.
Old Jul 4, 2007 | 09:30 PM
Rick's Avatar
Rick
defo no good in the rad!
Old Jul 4, 2007 | 09:50 PM
cfoster's Avatar
cfoster
Ok cool cheers, wasn't100% sure so thought id check! Mounting at the bottom of the swirl pot sound like an idea!
Steve.
Have you got a put of how its mounted at all Steve?
Chris
Old Jul 5, 2007 | 07:31 AM
foreigneRS's Avatar
foreigneRS
Testing the future
you want it engine side of the thermostat ideally chris, otherwise it won't read much until the thermostat opens.
if you're only interested in the hot temperature, then after the thermostat would be ok. in the rad would be fine if you put it right near the inlet hose which will be the same temperature as the outlet of the thermostat once it's opened fully. the further away from the inlet hose that you go either down or across will see the temperature dropping quickly
Old Jul 5, 2007 | 07:35 AM
cfoster's Avatar
cfoster
Ok so it may be ok to put in the rad right near the top hose then?! I'm not overly overly fussed about a 100% accurate reading, I just want to get an idea as to when its about to overheat
Chris
Old Jul 5, 2007 | 07:56 AM
foreigneRS's Avatar
foreigneRS
Testing the future
that'll do fine for that. you'll get to know what normal is, and then see when it gets hotter than that - unless it verheats because the thermostat is not opening
Old Jul 5, 2007 | 03:50 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Steve.
Chris
Sorry i ain't got a photo
It is a very nice bit of kit with a threaded bose for your temp sender, you just cut the hose and put it in the middle (you also have to cut the length of the hose down to fit)
It is very well made and was about £25 i think.
Steve.
Old Jul 5, 2007 | 06:08 PM
Fiecos Dan's Avatar
Fiecos Dan
i found best on a CVH is the lower hose on the stat housing.
Put it at least 50mm from stat, and that stops heat soak.
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
rsguy
44
Sep 29, 2015 03:29 PM
