T34 turbo hose to standard airbox on cossie fitment
Old Jul 4, 2007 | 04:24 PM
KSA-Cossie's Avatar
KSA-Cossie
Default T34 turbo hose to standard airbox on cossie fitment
How do you get the bigger diameter hose to fit the airbox,can you buy a reducer or what ?
Old Jul 4, 2007 | 04:59 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Read your post the wrong way around
probably, or a hose for that application as they're 'normally' used with cones...
Old Jul 4, 2007 | 05:02 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
make a sleave out of another pipe................pop it inside to reduce the size
Old Jul 4, 2007 | 05:09 PM
mechanic28's Avatar
mechanic28
you can buy a proper pipe then goes from 70mm down to 60mm can remember where from i will find it a post a link although i am sure samco etc do the pipe
Old Jul 4, 2007 | 05:10 PM
KSA-Cossie's Avatar
KSA-Cossie
Cheers m8.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
jaimesdna
Aug 25, 2015 06:59 AM
borboyous
Aug 22, 2015 11:17 AM
kosienutter
31
Aug 22, 2015 09:55 AM
