checking cossie fuel pressure...
is there a valve thing you can put a pressure gauge onto, or do you have to use a T-peice off of the feed line.
not you... lol
stu dont supose you know what the idle CO% of an off the shelf stg3 chip sold by PJ motorsport (ie ahmed) is... cant get thru to PJ on the phone (engaged)
just this second got thru to them...
they say std fuelpressure and 3.5% CO (Co screw is ignored when on boost tho aint it?)
also just to check a few settings off the top of my head... base idle (iscv unplugged) is 800-850 and fuel pressure with vac pipe disconnected is 3.5? yeah?
PassionFords Creator
Jim Galbally,
Other stuffs ok except set idle at 950 for best results.
Originally Posted by Stu @ M Developments
Jim Galbally,
Can you possibly explain what you mean by 'Best Results' with regard to setting idle at 950???
Originally Posted by b19bal
its not setting the car up, its checking somink out thats all
you dont know what we're looking at
anyway spadge, weren't you the man who wanted to wind his boost up in the carpark of the beds meet
jim knows better than to adjust/play with things, dont wanna get blamed if anything goes wrong afterall (different tinkering with you own car and not sum1 elses imho)
ps if i did want to set it up this is how i would do it (not that i do... just want to put your minds at rest)
check/adjust fuel pressure (if necessary)
check/adjust idle speed
check/adjust CO
re-check idle speed
re-check Fuel Pressure
re-check CO
repeat if necessary
wind actuator right out and unplug amal valve untill proper tuner can check it
check/adjust CO
re-check idle speed
re-check CO
repeat if necessary
dont worry spadge i know where you're coming from, but dont worry youve got nothing to worry about... we both know better
In fact i would no doubt benefit if you blew the fookin thing up so please carry on
Yeah, you meant run less boost than the mapper probably originally mapped it for and perhaps then run her on a possibly unchecked load site for prolonged periods of time...
Risky business... are you a gambling man?
kosienutter
31
Aug 22, 2015 09:55 AM
ekjim
Aug 17, 2015 08:57 PM
Zoggon
Aug 10, 2015 10:39 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
