battery light
Old Jul 3, 2007 | 10:32 PM
stookay's Avatar
stookay
Default battery light
my dashboard battery warning light has a faint glow , strangely when i press brake it lights up fully ! also rev counter drops 100 rpm and oil pressure gauge drops . any body got any ideas where to start looking for the fault ?? am lost
regards stookay
Old Jul 4, 2007 | 06:33 AM
Diode pack in alternator is buggered, unless you have a humungous drain on it such as ICE ?
If not ice then new alternator will cure it or just change the diode pack.
Old Jul 4, 2007 | 01:02 PM
Dave Henshall's Avatar
Dave Henshall
as above, mine did that for about 600 miles then the smoke came out and wnet completely, an exchange alternator was about Ł80
remember to remove the pulley and the heat shield off yours before sending it in as the exhange ones DONT have them fitted as std.
Old Jul 6, 2007 | 11:38 PM
stookay's Avatar
stookay
Default re light
thanks for the replys, the thing is , ive just put new alternator on car about 4 months ago , brand new from ford.
could it be a bad earth ? why should it glow when brakes pressed?
regards stookay
Old Jul 7, 2007 | 09:44 AM
M-ic's Avatar
M-ic
The brake light system draws another 50watts of power so when that happens with it already being in short supply, the lamp brightens up and the voltage dip makes the gauges go up and down.
Old Jul 8, 2007 | 10:18 PM
stookay's Avatar
stookay
thanks al get it checked out
regards stookay
155lee
Sep 6, 2016 11:10 AM
Flatlinedan
Sep 18, 2015 12:41 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
fuzzy
Sep 4, 2015 10:11 PM
