brick/building question - UPDATE nearly finished
need a little help please
this is a brick outhouse that i've got and will be using to house a couple of motorbikes
obviously the single door is not really convenient for getting 2 bikes through, so i will be knocking a hole in this end wall and installing a pair of 6' wide french doors
what i want to do is use the bricks from the french door hole to brick up the existing single doorway, but how do i get the bricks out in one piece and get the mortar off to be able to use them again?
i was thinking of slicing the opening in the end wall with a 14" diamond disc cutter and using several large but manageable chunks of still together bricks so that the amount of bricklaying and mortaring would be less. is that a good idea? obviously i'd be removing the half bricks at the side of the doorway at the moment and tieing in the chunks properly.
the wall is just a single skin of bricks.
alternatively, if it's too much of a ball ache to reclaim the bricks, is it cheap and possible to buy that amount of matching bricks, or will they look too different due to weathering over 40 years?
im 99% certain they are london bricks which are THE most brittle brick ever produced...so much so you cannot use them under DPC level. You will struggle to clean them up without chipping or breaking them. They are ready available to buy, are shit, but yet one of the most expensive bricks to buy
looks like a concrete roof aswell so you gunna need some sort of lintel and get a couple of akros to prop roof..
if you allready know all this tell me to shut up jus didnt want you to have a concrete roof on your head
sedan man thanks for offering advice
but it's not a concrete roof. there's several wooden beams running across from the side where the existing door is to the opposite side and these are covered with asbestos board and felted.
if i had taken a slightly wider shot, you would have seen that the concrete on the top of the end wall is just a capping for a couple of courses of bricks that are higher than the rest of the sloping roof that slopes away from that end. you can just about make it out by looking at both pics
so above the french doors will be a few courses of bricks but that's all. i figured that they would pretty much support themselves and the door frame by itself would be enough.
lee, thanks again for the advice. i'll take a couple up the builders merchants and find a match
but it's not a concrete roof. there's several wooden beams running across from the side where the existing door is to the opposite side and these are covered with asbestos board and felted.if i had taken a slightly wider shot, you would have seen that the concrete on the top of the end wall is just a capping for a couple of courses of bricks that are higher than the rest of the sloping roof that slopes away from that end. you can just about make it out by looking at both pics
updated - am i doing the right thing with the brickwork?
for the french door, i have cut out the opening and need to knock out the remaining bricks. have also cut a slot across the top for a concrete lintel
where the original door was, i have cut out the half bricks from each side so that i can tie in to every other course
think i'm doing it right, but just would like reassurance
i think you may have forgotten to install a lintel to hold the weight of the roof
Your going to need to get some of those acrows now i think so you can remove the bricks and put the lintel in. May have been easier to put the lintel in before removing the bricks but maybe not.
your about there ,but life would be much easier with a couple of Acros and 2 "strong boys" to hold the brickwork whilst you put the lintol in mate.
Or you will have to take pot luck that it dont fall in .
Or you could use a couple of lengths of 3by3 through the brickwork higher up above the lintol to take the weight of the brickwork.
as per righthooker but you could also do with a bigger seating area for the lintel. Youve got about 100-110 mm at a gues there and should really be 150mm at LEAST ...especially with those bricks as like i said before they are crumbly bastards. Make sure when you install the lintel you pack in plenty of mortar above it to hold the brickwork up above..
As the other said matey,get some lintels in place to support those roofs you can get steel ones or concrete.
I had steel ones put in on both my porch and kitchen doors, seem ok aswell,athough you lot will be the first to know if they aren't
thanks for the advice. there's not a lot of weight above where the lintel is going - only a couple of course of bricks andsome caps. none of the roof is supported by that area of bricks, there's a wooden beam running from the left hand side to the right just behind the end wall.
it's still up there this morning, so shouldn't be a problem
the hole for the french doors is 1800mm, the lintel is 2100mm so that is 150mm each side
righthooker yes i'll be doing the brickwork myself. i don't expect it will be brilliant for a first go, so have no problem posting the after pics up for you to 'laugh at'.
it's only an outhouse, so i'm not too bothered what it looks like. will probably be putting a trellis up on that side anyway
it's only an outhouse, so i'm not too bothered what it looks like. will probably be putting a trellis up on that side anyway take ya time and lay them 'frog' up
bit of a change in plan. i've also now taken out all the bricks that would havebeen above the lintel as there were a lot of crumbly ones in there. these will be replaced with ones that i salvaged from the area where the french doors will be
just got to try and learn bricklaying now
why frog side up lee? the building is built with frog side down all over?
Thats why it will be a tad weaker then and the bricks above the lintol wont have as good a hold.
Good luck and have fun
laid 3 courses in the door way so far, and put the lentil in place. looks alright. will look better after pointing obviously.
the key to it all is getting the mortar mix right.
the actual setting of the bricks is quite easy in the doorway as it is only a maximum of 5 wide and you have the existing levels there to guide you
last night i filled the 2 yard skip with old bricks and mortar and had a general tidy up so i can properly see what i'm doing and have space to work now
the actual setting of the bricks is quite easy in the doorway as it is only a maximum of 5 wide and you have the existing levels there to guide youlast night i filled the 2 yard skip with old bricks and mortar and had a general tidy up so i can properly see what i'm doing and have space to work now
nearly finished - just need to mortar the final coping stone in place and fill and level the floor.
pointing is a mess, left some of it too long before scraping it to shape
above french doors looks saggy in the middle as it was difficult to keep a straight line with the smaller bricks
overall, i'm reasonably ok with the result. it will be better next time. i wouldn't say i'm proud of it, but it's acceptable
where the side door was is going to have a trellis over it, so most of the bodge will be covered
really? as i say, i wouldn't say that i'm proud of it, but as a first go i'd say it was alright. didn't know if you professionals would see it the same way though - thought it might be one of those things like drawing that you can either do well or you can't.
but i think with practice it would get better. getting the mortar mix right and keeping it that way is the hardest bit, particularly without a mixer. and then knowing how much to put on the brick so you fill the right height without splurging too much out the side takes some practice
looks ok mate
when you were pointing it did you use your fingers at any point? tell the truth!
common to see non brickies getting the old index finger into action when pointing up
Originally Posted by dovboy
looks ok mate
Mc5506
Oct 5, 2015 09:57 PM
The Youth.
Sep 30, 2015 09:59 PM
