any brickies on here?
just wondering if anyone could give me a rough idea on how much to pay for the brick work on a small building we want done.
its 8.06m x 3.2m internal thermal block and outside normal brick with a 100mm cavity. will also have one large window the same width as a garage door and about 1.5m tall and a normal door.
me and a mate are planning on digging the footings and doing all the concrete work just need to get a brickie in to lay the bricks and dont want to end up paying through the teeth, we did have a quote for someone to do the whole job from start to finish and it was close on 16k with seems alot more than i was expecting.
cheers les.
cheers les.
Less than 2k brick - openings ,less than 350 blocks. just brickwork and blockwork,labour round here would be Ł450 per 1k bricks and 12 quid per m2 blocks .
So thats roughly 400quid blockwork and 900 quid for brickwork, bit for setting out and scafolding ,tressels would do a single story ,
thats presuming the building is 3.2 projection and 8m wide ,3 sides as an extension ,if its a free standing building then add on the 1k as lee has roughly quoted
righthooker
yeah i went above as the description isnt the best, so if he gets it cheaper then its a bonus to him lol!
Although we charge 15 per m blockwork for thermalites as you have to joint them
I do think youll get it cheaper though pal. Like i say i just went slightly above..
Materials depends. I think iirc thermalites are about 11 quid a meter and then bricks can be anything from 250 quid per 000 onwards...average is 350 inc vat...
cfoster
Feb 10, 2009 01:08 PM
GINGExR2 T
Jun 18, 2007 06:56 PM
Lee Reynolds
28
Jul 15, 2004 10:20 PM
