Anyone with RST FMIC's, GRS, AS, RADtech etc etc?
Old Jul 2, 2007 | 10:01 AM
Fiecos Dan's Avatar
Fiecos Dan
Default Anyone with RST FMIC's, GRS, AS, RADtech etc etc?
Could you please measure your intercooler cores for me?
Hieght, width and deepth please,
i have measurement for the Pro Alloy one already.
What i'm trying to do, is see what size cores RST's need for best ACT'S.
also if you have a ACT gauge, what temps do you see, and spec.
Cheers Danny
Old Jul 2, 2007 | 11:26 AM
gus's Avatar
gus
will make for interesting reading
Old Jul 2, 2007 | 01:13 PM
crazycage's Avatar
crazycage
fiesta turbo . radtech ,525mmx260mmx55mm. hope it helps
Old Jul 2, 2007 | 01:42 PM
Fiecos Dan's Avatar
Fiecos Dan
FRST radtec, 525 x 260 x 55mm, = 7518 m3 core area
ERST Pro alloy, 475 x 180 x 45mm, = 6435 m3 core area.
My Xr2tt 4wd cossie, 455 x 115 x 122mm, = 6384 m3 core area.
My Fiecos AH fabs rs500, 585 x 400 x 62mm, = 14508 m3 core area.
My xr2tt, see's 39oC at 6400 rpm in 5th, after a few back to back top speed runs. 1.6cvh, 2wd cossie T3 18psi, 200+ bhp
My cossie, 450bhp, gt30 26psi, 44oC on 28oc ambients and back to back top speed runs, 39oC with water inj on.
i've been looking at universal inters on ebay to replace my xr2tt 4wd cossie setup.
and looking at 550 x 180 x 65mm. = 6435 m3 core size.
Old Jul 2, 2007 | 02:05 PM
Bomber's Avatar
Bomber
Dan, I got a universal one: 450 x 300 x 76mm
Old Jul 2, 2007 | 02:18 PM
Fiecos Dan's Avatar
Fiecos Dan
That wouldn't fit on my car with out mod's that i dont want to do.
max core size to fit in the space, 600 x 180 x 125 mm.
Old Jul 2, 2007 | 02:35 PM
Bomber's Avatar
Bomber
Well in that case the Radtec one is too high for you then.
Old Jul 2, 2007 | 02:46 PM
Fiecos Dan's Avatar
Fiecos Dan
i'm not gonna buy a after market item made for a rST, As the prices are too high, and wont fit my car.
i just want to know the core sizes, for reference.
Old Jul 2, 2007 | 02:59 PM
Bomber's Avatar
Bomber
http://stores.ebay.co.uk/Intercooler-King
Cheap and cheerful - they've all got reference sizes on too.
Old Jul 2, 2007 | 03:10 PM
Fiecos Dan's Avatar
Fiecos Dan
this is one of the ones i was looking at.
http://cgi.ebay.co.uk/Intercooler-Lo...QQcmdZViewItem
Old Jul 2, 2007 | 03:13 PM
Bomber's Avatar
Bomber
Looks good - when the one turns up that I ordered (from the same shop), i'll get some close up pics of the welds, wall thickness etc.
The tanks don't look the best - but at £100... I can afford to try it out
Old Jul 2, 2007 | 03:17 PM
Fiecos Dan's Avatar
Fiecos Dan
i have been getting prices for 2, as i might put 2 together, and re make the end takes.
As that will be the best i could ever fit in the space i have, and will be fine for over 400+ bhp.
Old Jul 2, 2007 | 03:48 PM
Micky's Avatar
Micky
GRS,running hybred turbo at between 16-18psi.Never see more than 10C over ambient after 20 min sessions any time of year.Can't fault that!! Regards,Micky
Old Jul 2, 2007 | 04:17 PM
Fiecos Dan's Avatar
Fiecos Dan
could you measure the core for me please?
My xr2 or cossie never get hot ACT's on the track, niether dont go over 34oC on trackdays even in 29oC ambients,
Old Jul 2, 2007 | 04:20 PM
Micky's Avatar
Micky
Sorry Dan,but the car is 100 miles away from me parked up . Regards,Micky
Old Jul 2, 2007 | 07:02 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
its not just the size of the core that effects air charge temprature, other things such as if its a twin or single pass intercooler, the end tank design and the density of the cooling fins all make a major difference.
Twin pass GRS is the best
Old Jul 2, 2007 | 08:46 PM
Fiecos Dan's Avatar
Fiecos Dan
yes i know.
Old Jul 2, 2007 | 10:07 PM
Alex_86's Avatar
Alex_86
grs:
is:
h:28cm
l:57cm
w:6.5cm
comsi comsa
Old Jul 3, 2007 | 06:50 AM
Fiecos Dan's Avatar
Fiecos Dan
Now edited, and in order.
Originally Posted by Fiecos Dan
My Fiecos AH fabs rs500, 585 x 400 x 62mm, = 14'508 m3 core area.
ERST GRS, 570 x 280 x 65mm, = 10'374 m3 core area.
FRST radtec, 525 x 260 x 55mm, = 7'518 m3 core area .
ERST Pro alloy, 475 x 180 x 45mm, = 6'435 m3 core area.
My Xr2tt 4wd cossie, 455 x 115 x 122mm, = 6'384 m3 core area.
Ebay universal, 550 x 180 x 65mm. = 6'435 m3 core size.
Twin Ebay universal, 550 x 180 x 130mm = 12'879 m3 core size.
Old Jul 3, 2007 | 08:23 AM
Alex_86's Avatar
Alex_86
mine is the twin pass one though, dont no anything about the single pass
Old Jul 9, 2007 | 06:37 PM
Fiecos Dan's Avatar
Fiecos Dan
Even if its twin pass, the core is still the same size, but it might be more efficient.
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
`spotty
Sep 25, 2015 11:41 PM
Billy_RS
Sep 13, 2015 04:17 PM
