driveshaft problem
Old Jul 1, 2007 | 10:48 PM
dalsy70's Avatar
dalsy70
Default driveshaft problem
On the way home from Townley RSOC show , my CV jiont on the offside front driveshaft was very noisy, could feel and hear it getting gradually worse as the journey home wore on,
I need to get it replaced before the AVA rolling road day Sunday, where do I get a CV jiont from and roughly how much, what ones are the best
Old Jul 2, 2007 | 06:49 AM
Any decent motor factors should have one, or local car shop, always a stock item as not unique to the escos.
Old Jul 2, 2007 | 11:21 AM
ECOS95's Avatar
ECOS95
Ebay have some.
Item number: 250136963532
Old Jul 2, 2007 | 06:56 PM
dave cos4x4's Avatar
dave cos4x4
check your engine mount too,that may be fooked.
Old Jul 2, 2007 | 06:58 PM
S3an's Avatar
S3an
as said but dont rely on motor factors cv boots been any good, may fix one problem but could start another. also i found that a decent width cable tie is much better than any boot clips.
Sean.
Old Jul 2, 2007 | 11:41 PM
dalsy70's Avatar
dalsy70
Thanks Guys
dave ill check that tomorrow, cheers
I got a CV jiont today, eventually, so get it fitted tomorrow
I think the underlying cause is the boots burst, i see grease all over the inside of the wheel and wheelarch, so ill check the rest of them before they get fooooked too
Old Jul 3, 2007 | 06:14 PM
dave cos4x4
try and get genuine ford boots,like Sean said the others are crap.
one thing too,don't use cable ties as these expand when warm use the steel cable ties you can get.
Old Jul 3, 2007 | 11:17 PM
dalsy70's Avatar
dalsy70
The CV jiont I got was the wrong one, foookin nightmare, stripped it all out to have to put it back together again, i hate that
also found the inner CV is fooked too, so its new driveshaft time no fookin about, Ill get one tomorrow hopefully and check the engine mounts whilst am at it, never done it tonite as i was so pissed off
Thanks for the continued advise dave, much appreciated
Old Jul 7, 2007 | 02:06 PM
dalsy70's Avatar
dalsy70
Managed to buy a full driveshaft, and tried to fit it , but the old one WONT come out, NIGHTMARE!
had the thing right up in the air, trying to chap it out, but it wont come out the diff, anyone had similar problems or has a better technique in getting the damn drivshaft out
Old Jul 7, 2007 | 02:13 PM
cos jon's Avatar
cos jon
Probably won't come out your diff as they are secured with a circlip in the diff, so you'll have to drain diff oil and remove the circlip
Quite often the circlips are never re-fitted so your sometimes lucky.
Old Jul 7, 2007 | 06:17 PM
Stoo's Avatar
Stoo
You need a specialist tool called a 'TAC'. He almost pulled the front of my car off getting a driveshaft out lol
Jokes aside, can you not prise it out somehow? Although I'm sure you'll have tried. As far as I know nothings holding it in. Apart from the small circlip as said above..
Old Jul 8, 2007 | 10:01 PM
dave cos4x4
just do as Jon said.
take the diff plate off and you can see the circlip on the end of the shaft.
don't bother putting it back on as you will have a bit of play with the shaft then,saves it pulling on the bearing and boot,now it will slide in and out instead.
nice new oil in the diff too.
DAZZER
Sep 30, 2015 08:43 PM
mondeomark
Sep 28, 2015 06:28 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
