can you remove a FRST lump without removing the gearbox
Old Jul 1, 2007 | 07:53 PM
M K's Avatar
M K
Default can you remove a FRST lump without removing the gearbox
im swapping an engine for a mate while he is away, its on his fiesta rs turbo, but i forgot the bastard has ABS
so can i remove the engine with the box in situ? do i have to remove the alternator pully for clearance etc i just realy dont wanna fook about with the abs
any tips/info welcome
Old Jul 2, 2007 | 05:03 PM
M K's Avatar
M K
Old Jul 2, 2007 | 05:04 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
yes mate it can be a ass to get back in but ive doe it a few times
Old Jul 2, 2007 | 05:09 PM
xr4x4rs's Avatar
xr4x4rs
take off the alternator pulley
lye down while car is on teh florr still and crack it off
undo all teh shit you need to do, pipes,exhaust,wiring,etc
undo gearbox bolts from engine
put hoist on engine, undo engine mount and take off
lift engine up
Old Jul 2, 2007 | 05:15 PM
Oranoco's Avatar
Oranoco
Take the bonnet off completely as well as it gives you a bit more room to move about in and see what's what.
My bro and I removed his engine and box a few weeks back. Can't tell you about getting it back in as we're not that far in yet
Old Jul 2, 2007 | 05:21 PM
M K's Avatar
M K
cheers people
lift engine up
thats the kind of step by step guide i was after
Old Jul 2, 2007 | 05:31 PM
xr4x4rs's Avatar
xr4x4rs
take the rad out aswell as you dont want the engine to swing into it
you may need to jack the box up slightly if the engine becomes stuck
should be able to do it in less than a day mate
Old Jul 2, 2007 | 05:38 PM
pollocks's Avatar
pollocks
i tok the box out with mine and was really easy but then mine didn't have abs but i don't know how that affects it
Old Jul 2, 2007 | 06:02 PM
M K's Avatar
M K
abs is just a headache to unbolt, then you gotta pop out the safts, drain oil blah blah blah etc so would rather leave the box in
Old Jul 2, 2007 | 06:09 PM
gup's Avatar
gup
i normally take the crank pulley off too for that bit extra room done them all like this even removed a zetec lump like this
Old Jul 2, 2007 | 06:12 PM
djmillsy's Avatar
djmillsy
Fife Radge
ive done it in a mk 4 escort there a bastaed to get lined up and back in though
gup's Avatar
gup
ooops forgot to mention doesnt the driver side abs unit bolt to the block so you might still have to remove the drivers side drive shaft and abs unit
Old Jul 3, 2007 | 10:28 AM
ballin's Avatar
ballin
out isnt too bad, back in is a cnut tho
Old Jul 3, 2007 | 03:36 PM
M K's Avatar
M K
ooooh im filled with confidence now lol
Old Jul 3, 2007 | 03:57 PM
Roosie's Avatar
Roosie
usually takes a good 30mins to get it back in unless u have a lucky pop
Dr. Ickxs
Sep 15, 2015 10:15 PM
Si B
Sep 12, 2015 06:49 AM
Bransby
Sep 11, 2015 01:09 AM
grishenko45
Sep 9, 2015 12:58 PM
hopper350
Sep 4, 2015 12:53 AM
