Clutch Advice
Old Jul 1, 2007 | 02:25 PM
andyevo's Avatar
andyevo
Default Clutch Advice
Currently running a 6 paddle clutch in my escort and its in need of a change, which is the better, 4 or 6 paddle as i dont want it to fierce but need it to handle 430 bhp lol
Andy
Old Jul 1, 2007 | 02:36 PM
dave cos4x4's Avatar
dave cos4x4
the 4 paddle will be too rough.
are you having problems with the 6 paddle with that power?
Old Jul 1, 2007 | 02:43 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
I need a clutch as well for similar power/ torque, but need to handle hard launches as well - I was thinking a twin paddle set up
Old Jul 1, 2007 | 03:47 PM
rsdene's Avatar
rsdene
alcon 6 paddle and a heavy duty cover, think it can handle 440 lb/ft
smooth and light
speak to mike rainbird (randbmotorsport)
Old Jul 1, 2007 | 07:15 PM
RWD_cossie_wil
but can it handle hard launching?
Old Jul 2, 2007 | 07:17 AM
Aaroncast's Avatar
Aaroncast
hi possibly but not everything will!!!!! >>>>>diff<<<<<<renouned for launching problems(after launch!! lol
Old Jul 2, 2007 | 07:44 AM
rsdene's Avatar
rsdene
well i've really hard launched it but, best bet have a word with mike R
Old Jul 5, 2007 | 10:39 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Yes the clutch can (but will drastically shorten it's life), but the OE actuation cannot. The peddle will stick to the floor, the cable could snap or break the teeth of the ratchet mechanism. Continued launching will stretch the cable, cause the clutch to drag and basically be a totally pain in the arse.
Switch to hydraulic actuation and all of the problems will disappear, and then you're only faced with clutch life .
Personally, I would hydraulic the 6-plate single plate type first and see how you get on with that (however, tell Martin you are thinking of upgrading to twin plate later, as the arrangement changes slightly between the two, so it would be best to set the operation up to be compatible with the twin plate type just in case).
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
