will evo wheels fit skyline gtr
the stud patter will line up, but unless there of a 7,8 or 9 i think the calipers will foul wheels, also,
if youve got decent power, you should be running 18x9.5 or 18x10 wheels minimum,
ill go have a look at the ofset on my dads when it stops rainig
They will fit, but 37 is homosexual offset, it will look like a Cossie with the wheels miles inside the arches, so will need spacers.
9inch wide and mega low offset minimum IMO, even R33 rims are 9inch wide as standard.
9.5 or 10 ideally.
I prefer 17s but 18s work if low enough and right wheel.
10inch wide and ET20 sits just about perfect in the arches if you want a guide to how bad the car will look.
9.5 or 10 ideally.
cheers stavros...
10 inch et 20 it is then
but where the fook from,...
want compomotive mo1810 or mo 1890 but dont want to pay the lidiculous price tag they have attached....
carl
carl
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
