compression testing EFI car?
Old Sep 24, 2004 | 09:26 AM
M Brian's Avatar
M Brian
Default compression testing EFI car?
going do a comp test on my car (frst engined)...
whats easiest way to cut the fuel off so it dont fill the cylinders as im turning it over?
Old Sep 24, 2004 | 09:28 AM
Oranoco's Avatar
Oranoco
Disconnect the coilpack insted mate. Just remove the multiplug from it and then proceed as normal.
Old Sep 24, 2004 | 09:31 AM
Jim Galbally's Avatar
Jim Galbally
pull out the fuel pump relay
Old Sep 24, 2004 | 09:38 AM
M Brian's Avatar
M Brian
ah that not bad idea if can find the relay for it.
ah jim that reminds me.... wiring in a 24v cossie ecu injection etc etc.... how hard..
I want to know what tuning options there are for them?
do you know any carb conversions or anything?
off topic alert but its mine so fook off!!
Old Sep 24, 2004 | 10:07 AM
Jim Galbally
im not the best person to ask TBH i dont know much about em...
wiring's about 5-10wires to be joined... ive been told its piss easy but not done it myself.
tuning options there are a few, but they aint cheap...
personally im sticking to filter, xorst, chip and some nitrous and probably not takin it further
carbs yes seen a few with tripple carbs on the top. aparently they make awesome power like this on a stock engine
not for me tho, i like my EFI
Old Sep 24, 2004 | 11:03 AM
Rolls's Avatar
Rolls
melv- have you not got an inerta switch??, as thats the easiest way if its easy to find (mines in my footwell), or as steve says, the multiplug by the coilpack!
Old Sep 24, 2004 | 12:32 PM
M Brian's Avatar
M Brian
multiplug? by the coilpack!!! ah ah!! though he meant just the coil pack which wouldnt help on fueling!
Old Sep 24, 2004 | 12:36 PM
Oranoco's Avatar
Oranoco
I've always disconnected the ignition side when doing a compression test.
Old Sep 24, 2004 | 12:40 PM
M Brian's Avatar
M Brian
yeah yeah... but I don't want it fueling either! on EFI you can disconnect it!
Old Sep 24, 2004 | 02:20 PM
Rolls's Avatar
Rolls
in thats case disconect the coil plug one, and the iblet one- you get neither fuel or spark!!!!
EoinXR3
Sep 7, 2015 05:44 AM
marky_g
Aug 19, 2015 11:46 AM
marky_g
Aug 17, 2015 12:21 PM
taylora1409
Aug 12, 2015 12:06 PM
Zoggon
Aug 10, 2015 10:39 AM
