Cold Air = more boost?
Does colder air (ie 15< ACT's) allow the turbo to compress the air and generate higher boost more easily? I took my car out for a run the other night and instead of hitting the normal 17/18 psi it was hitting and holidng 20 with no problems.
Just wondering
Just wondering
Its setup for 24psi at the moment so no worries there
I didn't feel much difference in terms of power but the response was so much better as the turbo seemed to spool up that much quicker
depends what car and how the managemet works.
if it's quite primitive and gives full fuelling if the TPS sees WOT and the MAP sees some boost, then yes you could have overfuelling.
different boost at different temps is why things like boost cotrol was invented. you can't rely on a shitty bleed system (like amal valves) to give you consistent boost whatever the air temps. boost controllers or a proper ecu with integrated closed loop boost control is best.
Originally Posted by McPikie
If a car is set up for say..... 18psi, will it do any damage if you turn it down via the actuator to say, 16 or maybe 14???
Overfueling??
Overfueling??
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
