Bottom end...........
I have a spare bottom end which im going to rebuild, it seems in good health, no damage to tops of pistons and i turned it over via a spanner on the bottom pulley, smooth but with abit of friction which im told is ok ! Im just looking into what it will cost to rebuild, has anybody done it recently, and is it worth having the tops of the pistons shaved to lower the compression, lighting and balacing it, has anyone got any advice please.
Id like to run around 200bhp
If thats the case then ill just get the pistons cleaned up, what else do i need to do to the bottom end ive been told new shells, im looking to refurbish all the components in the bottom end. Prices please if people know.
new oil pump, with uprated flow if you can find one, but doubt you will, new sump whilst engine is out, there a cunt to fit in the car, new oil strainer pipe and all that gubbins
only thing about them ross racing piston you have to order them from U.S so you be waitng a few weeks for them unless someone stocks them but they are really good pistons
Cheers lads i have started to strip my spare bottom end, big thanks to redrsmk5 i have pics of me and martin taking the engine apart, will post in the restoration section soon.
I have a list of parts wanted including new sump and gasket and a new oil pump, shells, piston rings !!!!
If im going to build an engine then im only doing once !!!!!!
SMILER258
Sep 28, 2015 09:04 AM
