xr2i rev limit?
Old Sep 23, 2004 | 11:00 PM
wildy's Avatar
wildy
Default xr2i rev limit?
hi everyone!! first post on here
ive got a G reg xr2i, i just wondered if the rev-limiter is supposed to cut-in at just below 5000rpm, its more like 4800rpm? it seems to make it quite short legged?
Old Sep 23, 2004 | 11:03 PM
Jim Galbally's Avatar
Jim Galbally
no its not
sure revcounter is working ok?
also you might be in limp home mode, get qa gunstons fault code reader plugged in and check for faultcodes
Old Sep 23, 2004 | 11:08 PM
wildy's Avatar
wildy
cool ill check that out, as im new to the xr2i my knowledge is pretty limited, i take it that if there is a fault with the ecu/sensors then there isnt a dashboard light to indicate this, cant guarantee that the rev counter is working, it will hit the rev limter at about 60 in third (i think) it feels quite breathless
Old Sep 23, 2004 | 11:10 PM
wildy's Avatar
wildy
btw, would u know at what rpm the limiter should cut in?
Jim Galbally
should do 60 in 2nd mate...
no dash light... you buy the code reader witha built in LED... theyre about a tenner from halfords (made by gunstons)
insuruction manual is simple enuf
if no, take it toa ford garage n get them to put it on the startester n check for faults... be warned tho they normally charge a lot of money (complete ripoff imho)
Old Sep 23, 2004 | 11:15 PM
wildy's Avatar
wildy
fingers crossed for the gunsons then!!! mine at present would bottom out at 40 in second, hope this problem is easily solved, if theres a fault then hopefully it will explain the poor fuel ecomony and rough idle
Old Sep 23, 2004 | 11:17 PM
Jim Galbally
those are both two other signs of the ECU being in limp home mode... lol
Old Sep 23, 2004 | 11:21 PM
wildy's Avatar
wildy
does the limp home mode indicate that on of the 'important' sensors is at fault or any of the sensors are at fault
Old Sep 23, 2004 | 11:34 PM
Jim Galbally
not sure TBH
should only be an important sensor failing... ie one that that its been told that can fuck your car up if it does fail
Old Sep 24, 2004 | 08:03 AM
Rolls's Avatar
Rolls
limp home mode is normally indicated by the fuel pump running perminantly when you prime it- instaed of priming for 3 seconds, it just runs constantly!
Old Sep 24, 2004 | 08:17 AM
Oranoco's Avatar
Oranoco
Having had a tweeked XR2i 8v until very recently I can say it sounds like you have problems.
I beleive the rev limiter should cut in at about 6200rpm and you should pull just shy of 60mph in 2nd gear. If you are in doubt about tackling this sort of thing you may be better off booking it in with a specialist to sort as they will have the equipment to diagnose your problem(s). What area are you in as PassionFord has people all over the country so wherever you are somebody on here is bound to be able to recomend you a company that will help you and not rip you off.
Old Sep 24, 2004 | 08:28 AM
Ryan's Avatar
Ryan
see wildy there a helpful bunch
Old Sep 24, 2004 | 08:44 AM
Ryan's Avatar
Ryan
he's in southampton down the road from me, is there a process to reset "limp home " mode?
Old Sep 24, 2004 | 08:47 AM
Jim Galbally
if you not got a faut code reader... just unplug the ECU for about a minute n put it back in
or disconnect the battery
but it'll probably go straight back in as soon as it detects the fault again (assuming you havent fixed the problem)
Oranoco's Avatar
Oranoco
I beleive (although not 100%) reset can only be achieved once the fault has been rectified. It really needs looking over by somebody who knows what's what.
Old Sep 24, 2004 | 08:48 AM
Rolls's Avatar
Rolls
you need a gunstons fault finder- you can then rest the ecu after doing the dianostic tests- go for a drive, and see if the same error codes are in the KAM!- should help to narrow down the problem!
Ryan's Avatar
Ryan
cheers jim.
seem's easy enough to solve.
will get him to buy a fault reader, and i'll have a look over the weekend
Old Sep 24, 2004 | 08:49 AM
Rolls's Avatar
Rolls
bugger- beaten to it!
Old Sep 24, 2004 | 08:51 AM
Ryan's Avatar
Ryan
cheers boys much apprieciated
Old Sep 24, 2004 | 08:52 AM
Jim Galbally
rich, you tried yours chipless yet?
Old Sep 24, 2004 | 08:58 AM
Rolls's Avatar
Rolls
to to asda for mum at 10 matey! - didnt wana go during rush hour!
Old Sep 24, 2004 | 10:20 AM
wildy's Avatar
wildy
Cheers for everyones help!!!!
im gonna get on the case with it this weekend!!!! or at least ryan will lol
Thanks again
Old Sep 24, 2004 | 10:29 AM
wildy's Avatar
wildy
just checked the situation with the fuel pump, it does only prime for about 2-3 seconds , then switshs off
Old Sep 24, 2004 | 11:02 AM
Rolls's Avatar
Rolls
thats a good sign matey- not in Limp home mode at least!!!
Old Sep 24, 2004 | 11:04 AM
Ryan's Avatar
Ryan
so what else could it be then
Old Sep 24, 2004 | 11:05 AM
Jim Galbally
still check it with the fault code reader...
do ignition on test and see what codes are in the KAM (the 2nd set of codes)
then reset KAM, take it for a drive (make sure to hit this limiter) and check again
Old Sep 24, 2004 | 11:06 AM
Rolls's Avatar
Rolls
go to halfrauds, and get a gunstons thing matey- nice an easy to use (once you get used to it), and will help you diagnose the fualt!!!
SMILER258
Sep 28, 2015 09:04 AM
Andypandy260
Sep 23, 2015 10:28 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
