Magnex or Mongoose?
what exhausts are guys n girls you using and do you have any preference? ie performance , noise, build quality and more imortantly fitting quality...... Trying to decide what exhaust to buy??
I dont think ive ever see one of these Blue flame jobbies.... dont suppose anyone has any pictures of theirs?
The only thing putting me off the mongoose is that they seem to hang quite low, kinda away from the body if that makes sense? where as the magnex fits right up in the floor pan.... just an observation - i could be wrong?
mongoose is straight through one pipe and on 4x4 removes cat
magnex mirrors standard system and on 4x4 is cat back system. alot easier to pass mots emissions
but both systems are superb but mongoose obviously flows better due to it being one pipe with no cat
Scorpion reduces insize SLIGHTLY to offer some back pressure, needed for a turbo engine!!
Mine is std and 3 1/2" is the minimum size which is ample for at least 600bhp.
With scorpion you can also buy a pipe to replace centre box if you wish, mine makes ace power with scorpion.
I have a Mongoose and its alright but getting a little tired now. I like the Magnex system and it fits better and is a little less noisey.
If i was going to buy another off the shelf system i would go for the blueflame for the price i can get them for. I had one on my old car and as has been said its the same as a mongoose except it has bolt flang. The reason they are the same is because Blueflame used to make all of Mongoose's systems.
A turbo engine needs back pressure?
Extensive testing has been done on the exhust on my car and it is the size it is for a reason.
Back pressure helps a turbo engine to develop more power.
NOTE "mental" tabetha did NOT say LOADS of backpressure but a certain amount helps, this would be arrived at by testing to see how much, but other things will alter this amount, most particularly cam choice/lift.
i have a magnex on mine now with a mongoose 4" backbox lovely and quiet but just right when it needs to be,seems to drive better than before when it had the scorpian on with the centre box removed
Extreme from woodford garage (before Sue collins got involed!!)
Based on a mongoose with bolt flanges and prop and diff hangers and a 4" slash cut(bit different anyway)
Excellent imo
Excellent imo
Excellent imo
Excellent imo
I had a really nice slash cut on my car with a magnex system before i changed to the blue flame, 4" too, strangely enough i really liked it but prefered the outword rolled 4"
JK12
33
Apr 26, 2021 12:09 PM
