where can i book a track day at croft
Old Jun 26, 2007 | 07:14 PM
biscuittin's Avatar
biscuittin
Default where can i book a track day at croft
as titled , know i could try croft , it would be a good place to start
but what i mean do they have a web site or do i go through an other party to book one .
if so can some please give me there web address
thanks
Old Jun 26, 2007 | 07:36 PM
NUTS RuS's Avatar
NUTS RuS
Ł160 this Saturday with trackdays.co.uk ?
Croft direct is at http://www.croftcircuit.co.uk/car.php
Old Jun 26, 2007 | 08:00 PM
biscuittin's Avatar
biscuittin
thanks just had a look they are fully booked up till sept
wanted to do a track day there in july
thanks though , would have done this weekend but im busy
would do oulton park ,but i need a cheap ish track day first to see if i've fixed the oil leak my car has , it only does it on the track you see .
might just bite the bullit and book oulton , if it's not right i could just put the cossie on
Old Jun 26, 2007 | 08:32 PM
NUTS RuS's Avatar
NUTS RuS
21st July with http://bookatrack.com Ł160
Loads of places do mid week stuff if your just testing.
If you do have an oil leak PLEASE dont take it out on track
The new Anglesey circuit is fantastic if that is any good for your location ?
Old Jun 27, 2007 | 05:43 AM
Redkop's Avatar
Redkop
Cheap day at Dono on 22nd July
http://www.donington-park.co.uk/trakzone/
Old Jun 27, 2007 | 07:33 PM
biscuittin's Avatar
biscuittin
thanks nuts rus i saw that one on the 21st
the oil leak only happened when the car was on the track , but ive found the problem the crank shaft oil seal had come out
i've modded the breather system aswell , just in case it was building up pressure???
but you know how it goes just not 100% should be as that could have been the only problem
i live in blackpool , thats why i want to do croft or oulton as they are the closest tracks to me ( croft is cheaper , just in case i have not fixed the oil leak )
how strickt are they on noise as the fiesta tested at oulton at 102bd at 4500 rpm
thanks lynne looked at the one as well , but donno have a noise limit on that day you dont know what it might be do you ??
it says road silenced on that day !!!!( not sure on the db limit )
Old Jun 27, 2007 | 08:00 PM
NUTS RuS's Avatar
NUTS RuS
Venues are getting more strict with noise as people keep on pushing their luck.
Expect at the least to get a warning if your levels are above the limits, and at the worst they wont even let you start until its sorted.
Dont think that because they havn't tested you they are not bothered. If you are noticably above what is the accepted level they will pull you in. The marshals around the circuits have a trained ear and are usually linked by radio back to control.
102db is getting close to a time you did something about it
Anglesey is another good option for you now its open, its the newest circuit in the country and for you is all either motorway or dual carriage way to get to apart from the last 2 - 3 miles. So its an easy drive
Old Jun 28, 2007 | 06:37 PM
biscuittin's Avatar
biscuittin
thanks will give angelsey alook once i'm sure i've fixed the oil problem 100 %
do you have a web site for them
Old Jun 28, 2007 | 06:48 PM
NUTS RuS's Avatar
NUTS RuS
http://www.angleseycircuit.com
ossie cossie
57
Nov 21, 2022 10:05 AM
BRAM
Sep 8, 2015 07:11 AM
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
Shows & Track Days
Sep 4, 2015 07:16 AM
