BD10's
I have a 2wd cossie with 3" Mongoose, KN, Montune Chip, Turbonetics T34 ar.48, RS500-cooler, grey injectors, low compression pistons, and ported top (???). Had it on a rolling road and the results were 350bhp@6100 rpm., and 417nm@4400rpm. 1,6 bar.
Is it worth buying BD10's?
Because of the small exhaust-housing i can't have more than 6000rpm. (Don't know what you call it in English. Back-boost???
Preassure/boost in the exhaust-housing). Will new camshafts help with this problem? Will i loose power on low rpm?
In January 2004 edition of Performance Ford they added bd 10's to a car, spec =
T34, 22psi boost,standard comp,radtec RS500 i/c,4 x grey injectors,L8 ecu and pectel board.
The power was 310.9 bhp at wheels before cams fitted.
After cams were fitted...324.2 at the wheels.
So, not too bad a conversion considering the standard cams supposed to be o.k.
Dave.
Dave.
Danielbetty
Oct 3, 2015 06:01 PM
