bhp what mods
Old Jun 26, 2007 | 11:28 AM
morrison's Avatar
morrison
Default bhp what mods
hiya all,i have a standerd erst with k&n and mongoose exhaust system.Im looking for around 160,170 bhp how can i get this,also how much boost can i run without any damage on a standerd engine thanks for the help
Old Jun 26, 2007 | 12:02 PM
T28 RST's Avatar
T28 RST
Ok then
Add a GRS front mount intercooler, bin the filter for a standard airbox, chip it and run 16psi and you will have around 170 - 180bhp
Old Jun 26, 2007 | 12:35 PM
turbo's Avatar
turbo
as above really with a -31, think you can get around the 170-180 brake if you got a heathy engine
Old Jun 26, 2007 | 01:03 PM
zippyobrien's Avatar
zippyobrien
just need a nice chip, set up and -31 actuator, with a front mount, youd be getting close to 200 bhp depending on how healthy your turbo is
Old Jun 26, 2007 | 01:24 PM
morrison's Avatar
morrison
okay cool thanks all,how much is it to get set up?will it be ok 2 run 16psi?that sounds like alot?or am i bn stupid also is it the chip that needs set up so i cant just plug it in, thanks for the help
Old Jun 26, 2007 | 01:27 PM
JimmyBoy's Avatar
JimmyBoy
I thought 14psi was about the max you can use on standard pistons.
Old Jun 26, 2007 | 07:45 PM
T28 RST's Avatar
T28 RST
Ok then
The pistons will handle 16/17psi
Old Jun 26, 2007 | 07:51 PM
Oranoco's Avatar
Oranoco
My brothers FRST was peaking at 22psi and holding 19psi on stock pistons with no bother at all for almost two years. Only reason it's apart now is for a freshen up but everything was still good when it came apart.
Wouldn't recomend running at these levels though
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
SMILER258
Sep 28, 2015 09:04 AM
