Cossie dyno run
Had my cossie dyno'd today and here's the spec
green injectors
500 cooler
big filter
3 bar
T35 turbo
stage 3 chip
Here's the results
The boost dropped off big time due to the actuator opening at 5psi so he reccomended a -34 as it opens at 14 then should see over 300 which i'll be happy with for noe
green injectors
500 cooler
big filter
3 bar
T35 turbo
stage 3 chip
Here's the results
Originally Posted by pete mcrash
maybe just a new actuator fella...........dosn't have to be a -34
saff is working!!!...atm
Originally Posted by coswurv
it boosts to 20 then drops off to about 16-17 and im not sure about rear housing i think i was told .68 if that sounds right ?
Karl 3dr
102
Oct 14, 2016 08:17 PM
kosienutter
31
Aug 22, 2015 09:55 AM
yawiejon
15
Aug 9, 2015 06:36 PM
