Coilover help
Old Jun 25, 2007 | 04:17 PM
morty's Avatar
morty
Default Coilover help
I recently bought a fitted a set of Avo coilovers, however when fitting only found out they had one tighting cup.
These when screwed down are worthless on the car as the spring sits loose.
The car will only probably be used on the roads and not track use.
Any ideas as to what Coilovers to buy?
How much could i sell my own Avo ones on for?
Old Jun 26, 2007 | 12:05 AM
morty's Avatar
morty
anyone?
Old Jun 26, 2007 | 07:29 AM
Get longer springs then, they are std 2 1/4, 2.25" spring very cheap.
Old Jun 26, 2007 | 10:15 PM
NUTS RuS's Avatar
NUTS RuS
As above. Call AVO and get them to supply some longer springs.
There is no need to sell them
Old Jun 26, 2007 | 10:35 PM
Kelv's Avatar
Kelv
Almost there!
Do the springs state there poundage and length atall?
Old Jun 28, 2007 | 06:45 AM
They have poundage marked but not length but that is only a ruler away!!
Old Jun 28, 2007 | 12:12 PM
Kelv's Avatar
Kelv
Almost there!
My old gaz setup had each spring labeled with length and poundage.
Old Jun 28, 2007 | 03:53 PM
cossymad's Avatar
cossymad
As above the GAZ ones are labled, but if you have the poundage, it is possible to change spring length.
I can't see how they can be loose though, as when let down the car weight holds them in place
Old Jun 29, 2007 | 02:46 PM
morty's Avatar
morty
But it is clearly a problem for MOT in Northern Ireland as when they jack the car up if it sits loose they fail the car. Their is no comfort what so ever when driving the car at the moment due to the suspension.
The car is still sitting like a bus too.
Old Jun 29, 2007 | 03:04 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Where did you buy the suspension from?
Ask for the rear springs to be changed, and ask if they can supply some helper springs (these support the main springs so they don't rattle around) to comply with your MOT regs.
If you have any trouble, then I can help you out .
Old Jun 29, 2007 | 06:27 PM
morty's Avatar
morty
i bought them off Demon Tweeks.
The problem seems to be that there is only one hlper spring and on most other sets of coilovers there are at least 2 one to adjust height and one to secure spring.
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
