Kent, Piper, Newman, NMS special grind??
OK guys, are there any discernable differences between camshaft kits for an ERST?
Who uses what, which produces most all out power, which produces most torque?
I used to have a Piper in my old ERST and it only felt like it kicked it from 4k upwards. Obviously, with the fiesta, that would be useless, so I am looking for something with a bit more torque and drivability.
Originally Posted by Chris@torque of the devil
I have recently fitted a newman kit with solid lifters and it performed very well, i took out a piper 285 T that was causing a misfire at 7100 rpm
As they can ALL be the same CAM just made by different people, ie same duration lift etc, it does not follow that one would cause a miss and another not, unless it was faulty, ie worn away, wrongly made.
Most cam makers copy everyone else's anyway.
Mc5506
Oct 5, 2015 09:57 PM
