RS Diagnosis/Tune up in the north
No longer a ford owner ..
Having real problems with my car at the moment, it wont start.
Compressions there, fuels there and spark is there.
Ive tryed everything I can think off (Fuel relay/fuel pump/Gaskets/imobbiliser..)
TBH im getting sick of throwing stuff at it, I need the starting problem fixing and it set up/checked over so I know its ok! So I can enjoy it whenever we happen to have a sunny day!
Im from the Middlesbrough area, I could get it trailed somewere, maybe Well lane or something, but do they do Diagnostic work? And itll be left there till fixed so I need somewere were it will be secure on a night!
Well lane are a waste of time for stuff like this
Just trailer it down to Msd mate they'll more then likey have it sorted and set up within a couple of hours.
Thats where mine goes when I have any problems and it's always sorted. Theres no one beside us thats any good mate, just book it in and get it done properly
Yeh its a S2. Its not the leads! Ive had problems with pipes popping off but Ive checked it over loads of time and I cant find any off.
Was running ok, went to start it one day after having it out and it just wouldnt start, trys to sometimes but it wont.
I had problems before with the fuel so its got a new(ish) fuel pump, relay ect and that ended up being the immobiliser!
Getting a nice spark, so I cant see if being anything that side. And the compression is spot on. And theres plenty of fuel (Not got anything to check the pressure with)
So I really need someone who knows what they are doing with RS's
Im more use to working on brand new Vauxhalls
Will have to find someone with a trailer now, Anyone fancy a drive to sunny Blackpool?
Have u tried depressing the metering flap ever so slightly while somone cranks it? Is the fuse to the fuel ECU ok? Have u tried tow starting it?
Yeh tryed pressing the flap but nothing, also tryed starting it when I was getting towed back but no luck. I checked all the fuses in the box, they are all ok.
have you changed the black fuel pressure box on the metering unit? my s1 had the exact same prob as you had fuel spark etc just wouldnt start changed that and it was spot on
worth a try
worth a try
carwise are a bit closer, York.Have you not rang them?
put this post in technical help some 1 in there might b able to help ya. Safechav is very good with cvh/rst,and he is always in there
Originally Posted by BigErn
milkman were you at V Sport the other day?
Dont know you but Im guessing it was you??
I knew I reconised your plate
When we left all we could see is black lines all over the road ya mad cunts
whens the next open day on?
Cars booked in for the 10th July! Just have to get my Intercooler, Rad and fans fitted! They havent even arrived yet
Couple of my pals want to come so they can go on that massive roller coaster
Managed to get it started, it was the valve timing
Btw who was it who left the fook off tyre marks on the wrong side of the road?
Must have been about 100+ yards long
Well thats what its rear wheel drive for!!!!
TT T38 Power
I would like to go on that roller coaster as well
Steve.
23
12-09-2015 12:56 PM
