Which adjustable fuel pressure reg ?
Im thinking of fitting a fuel rail with JIC fittings and rather than just use a 2wd reg with hose clips on it i was mibi going to uprade the reg to one with JIC-6 fittings. Any recomendations???
Seen this on ebay looks to be a copy of the Aeromotive ones but half the price.
http://cgi.ebay.co.uk/Custom-DSM-4g6...QQcmdZViewItem
IMO leave anything alone that was sold by XS Power. It is all cheap shit. A Fuel Pressure Reg is such an important part of the engine, why skimp on it? It's not like the Aeromotive one is that expensive. Around a ton I thought.
Very true
just didnt know if anyone had tried the xs one, know there manifolds and coolers are ment to be prity bad. Will check up on the aeromotive ones, anybody know where to get them other than ebay.
Im not bothered about the bling side of things just dont see the point of using jic fittings for the fuel system and rail then having push on fittings with a clip on the reg. Is the group A reg just a 2wd style with jic fittings ? Where can i get one ? Tim was going to bid on the one you had on ebay the other week but it got pulled.
Sorry Tim thought it was you that had a reg and hose forsale the other week, same time as the R&D front diff. IS the group a similar to a 2wd but with jic fittings? You wouldnt have any in stock would you?
JK12
33
Apr 26, 2021 12:09 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
strate to the point ...just to add thers nothing wroung with the 2wd ones
