4X4 OIL PIPE ONTO A 2WD
Originally Posted by Alvyn
grind away the bit of the 2w/d sump that it hits against!
You adjust the oil spray bar pipes with a pair of water pump pliers and then adjust the nozzles that point under pistons 1 and 2 to line up properly again - takes all of 2 mins
[quote="Alvyn"]
and weaken the sump? no chance.
To make it fit by grinding the sump, you need to remove at least 5mm of material in the area the pipe contacts it. now how thick is the sump there? about 6mm tops - leaving not much material at all.
[quote="Graceland"]
well the last ones that I know that have been done DIDN'T need alot taken off to miss and ARE still in perfect working order so
back at you
back at you Trending Topics
FlashRS
13
Aug 31, 2015 06:02 PM
mrmann
Aug 20, 2015 11:24 PM
