Starting car that's been stored for 7 months
Old Jun 23, 2007 | 09:49 PM
Oranoco's Avatar
Oranoco
Default Starting car that's been stored for 7 months
Anything I should do?
Haven't moved my S2 since begining of November and really want to get it out the garage for a clean up and coat of polish to show I still care
Unfortunately the house move and associated work plus my work commitments has meant I've not spent the time or money on her I should have
Old Jun 23, 2007 | 09:58 PM
Brookesy's Avatar
Brookesy
Could do with some fresh petrol as it will seperate after 2 months & gunk up inside the fuel lines
Old Jun 23, 2007 | 10:00 PM
Oranoco's Avatar
Oranoco
Bugger I stuck Ł30 in before laying it up
Old Jun 23, 2007 | 10:02 PM
mercury grey minter's Avatar
mercury grey minter
Just started mine today after 8 months of it in the garage.
1.FRESH OIL
2.NEW OIL FILTER
3.NEW FUEL FILTER.
Check trye pressures.2 of mine had lost 15 psi.
After changing them items,i started it up and left it running for half an hour to check if any seal/gaskets had perished and anything leaking.
Just my starter motor that was f*ked.Don,t know why.
No problems with petrol for me.Was nearly empty so just stuck a fiver in it.
Old Jun 23, 2007 | 10:03 PM
Brookesy's Avatar
Brookesy
You can get this additive you put in the tank stops the petol from seperating a lot of classic car owners use it when they store their cars for months
You can get it from Frost.
Old Jun 23, 2007 | 10:05 PM
Oranoco's Avatar
Oranoco
Will bear that in mind come next November when I put it to bed
Kind of shutting the stable door after the horse has bolted for me at the minute
JoeyBoyden
Jan 4, 2024 02:36 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
track.focus'd
Aug 12, 2015 05:53 PM
Adam-M
22
Aug 10, 2015 10:46 AM
