turbosmart dumpvalve
hello,
i have a question. a mate of mine has a turbosmart megasonic dumpvalve. but it is not sissing at all. his old dv is working well. so there is no vavuum prob. but when we put the turbosmart dv back on then there is nothing. you can adjust the dv from soft to hard. but nothing.
somebody has any experience with this. do we have to modify something.
the cos is running 21psi.
Originally Posted by sunny
You can hand-twist the end to adjust the spring pressure.
Thanks - Sunny.
Thanks - Sunny.
i know there is on top of the dv you can twist this little thing ehich is connected to the vacuum hose
or can i adjust more?
wim
ok sunny.....i just talked to my mate. he told me he did adjust the whole blue end to the max it can for the hardest sound. but it didnt worked. he didnt hear anything.
he putted the old piston dv back on and it was sissing loud.
strange......
strange......
Originally Posted by Itsmeagain
maximum is hardest spring, its not opening, tell him to twist the fucker the other way!
but thanks anyway
its this one which doesnt work properly. the scription tells you to use a 5mm vacuum hose. but there is not a 5mm connecting on the inlet manifold.
someone can give me an idea
cheers
cheers
cheers
cheers
I had one of them on my old S2 and then on my Cossie for a while. Didn't need to adjust anything at all
And now KeithG666 has it on his S1 and it works great apart from being
Sorry I can''t offer any help though
i tried the valve on hard on soft in the middle but it stay's the same and in the discription they really advise you to use a 5 mm vacuum hose but the stange thought i had that the connection on the inlet stay's the 2,5 mm so just changing the vacuum hose wont be enough ???
Does anyone have such a valve fitted on a cvh or cossie engine ????????
Originally Posted by Rich@rd
No, because the dv from Richard in his blue escos (de groot) didn't also do very mutch.. So it must be a coinsidence (spelling) that they both fooked
jessie_rs
11
Jun 3, 2019 04:57 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
rsstav
Aug 11, 2015 04:22 AM
