2wd saph what are flat out speeds on standard drivetrain ?
Old Jun 22, 2007 | 06:32 PM
scoooby slayer's Avatar
scoooby slayer
Default 2wd saph what are flat out speeds on standard drivetrain ?
hi was just wondering what speeds in each gear people are getting from 2wd saphs on standard drivetrain when hitting the limiter?
Old Jun 22, 2007 | 09:39 PM
rapidcossie's Avatar
rapidcossie
standard size wheels amd tyres?
Old Jun 23, 2007 | 06:15 AM
Road speed at given RPM =
60 X Engine RPM / Divided by Wheel Revs(mile) X Axle Ratio X Gearbox RATIO.
So that is, 60 X 6500(rpm) / 897X3.64XGearbox ratio.
I don't have the gearbox ratio(to hand) so I looked in the FORD booklet instead.
Cossie max speed is as stated
1st = 40
2nd = 62
3rd = 89
4th = 119
5th = 149
This is what ford say in the booklet that came with the cossie, so if inaccurate down to them.
Old Jun 23, 2007 | 10:55 AM
scoooby slayer
Default reply to tabetha
as always your a fountain of knowledge mate thank you.
im gettin 105 mph in 3rd and my speedo isnt far out, my rev clocks saying 6500 rpm so really im probably over 7000 rpm anyway.
thanks mate
Old Jun 23, 2007 | 11:06 AM
"fountain of knowledge", no I just looked in the booky.
Old Jun 23, 2007 | 04:46 PM
2001ode's Avatar
2001ode
Just a little change :
60 x RPM x wheel rev / (axle ratio x gear ratio)
Regards
Claude
Old Jun 23, 2007 | 07:35 PM
Beg to differ matey but you are incorrect.
It is as I said, example,
60 X 5000(rpm) = 300,000
897(wheel revs/mile) X 3.62(diff ratio) X 0.73 Gear ratio(top) = 2370.4122
= 300,000 / 2370.4122 = 126.56
NB this is just an example not necessarily applicable to the cossie.
Old Jun 24, 2007 | 10:53 AM
scoooby slayer
Default tabetha
just got gearbox ratio and added up. your right tabetha.
at 7500 rpm 1st 43 , 2nd 71 , 3rd 103 , 4th 138 and 5th 173
my rev clock must be showing 6500 rpm when its really 7500 rpm.
i think il stick to no higher than 6000 rpm on me rev clock dont wana kill the old girl
thanks people
Old Jun 24, 2007 | 01:48 PM
They have rev elimiters(ecu), but safe to 8000 all day long anyway!!
Old Jun 24, 2007 | 03:12 PM
scoooby slayer
Default tremec t56
ive just done the ratios for a tremec t56 at 7500 rpm would be 1st 46, 2nd 66, 3rd 96, 4th 138, 5th 173 and 6th 223.
does anyone know if speedo would be correct if this box fitted ?
Old Jun 24, 2007 | 03:25 PM
So long as the drive(cable) turns at 1000 times a mile then it is correct.
James Porter
Oct 28, 2015 12:17 PM
FlashRS
13
Aug 31, 2015 06:02 PM
ray barker
Aug 7, 2015 09:00 AM
Old ford
Jul 31, 2015 06:50 AM
