JIC fuel rail hoses
Im looking to mibi fit a jic fuel rail, so just wondering the best place to get the hoses. I have a 2wd reg and a jic rail with fuel pressure gauge take off. Also how do you connect onto the original pipes, just with hose clips or a olive compression fitting to jic.
http://www.summitracing.com/
They are in the US and cheap. You can buy online with ease as everything has pictures etc.
Very quick delivery also.
Was going to just buy the hose, cause we have all the jic crimps and fitting you could ever want on my rig but eayer to just buy hose and fittings on the beach.
I have seen a fitting before that is a straight tube with a flair on one end and a -6 jic fitting on the other end, would be perfect for rubber lines but I suspect your talking about the OE plastic fuel lines ?
Either way try thinkauto mate as they are very helpful, dont ask them what thread a 2wd reg has though as they wont have a clue lol
The escort has metal lines up to the bulkhead then the rubber hoses clip on, so a compression fitting to jic will work.
Has anyone drilled the nipple off of a 2wd reg and tapped it out for a npt to jic fitting?
Iv braised -6 fittings either end of my original rails. It's do in the mean time
Thats what i have Jam its standard rail with JIC ends and gauge take off, just the hoses and regulator fittings i need to sort out. Was it Zoo that Euan got his from or Carwise.
his is a Zoo motorsport one. Carwise do them too but look as good.
Guy doin them on ebay now, i'll find the link for ya.
Just outa curiosity mate, what fuel pump do you use??
http://cgi.ebay.co.uk/YB-Cosworth-Bi...QQcmdZViewItem
Thanks for the link they do look
, but think im just going to go with the one i have in the shed.
I think its a 044 or so it says in the mags it was featured in. Sure Hinks said it was a group A pump.
i still have some rails left and i sell all the pipework from old stock i have laying around compression fitting onto the steel line in and jubilee clip on the return side using a 2wd reg you have no choice to use fuel pipe clips like standard
Thanks alot Brom will give you a shout next week to get some bits ordered up once i check to see if i still have the rail in the shed. Do you take paypal ?
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
Russ Payne
Sep 25, 2015 08:29 PM
