drive shafts
Old Jun 21, 2007 | 05:28 PM
sy.rst's Avatar
sy.rst
Default drive shafts
does anyone know if xr3i drive shafts and cv joints are the same as s2 rs turbo drive shafts
Old Jun 21, 2007 | 06:17 PM
haz87's Avatar
haz87
Yes they are
Old Jun 21, 2007 | 07:14 PM
addiction's Avatar
addiction
RST shafts have teeth on them for the ABS
Old Jun 21, 2007 | 08:13 PM
Micky's Avatar
Micky
That is incorrect,the inner CV has teeth for the ABS belt,but if you have removed the ABS then the XR3i inner CV's will do.If not,only the XR3i driveshafts and outer CV joint's can be used.Regards,Micky
Old Jun 22, 2007 | 12:11 AM
jonesymk2's Avatar
jonesymk2
surely the xr3i driveshafts are a bit longer so wont be able to connect the driveshaft to the rst cv joint at the gearbox if it has abs as the cups are longer arent they,if they arent longer then i appologise as i dont want to sound like im arguing
Old Jun 22, 2007 | 08:23 AM
zippyobrien's Avatar
zippyobrien
alot of xr3i had abs to
and there intachangable, as yu can put a x3i gear box and rs turbo gear box into an xr3i,
Neil Clark
21
Oct 1, 2015 07:02 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Bransby
Sep 11, 2015 09:12 PM
rsstav
Sep 7, 2015 04:43 AM
