bias brakes
Jun 21, 2007 | 04:08 PM
bias brakes
i had a thread about this a while back but since then ive seen 2 cars with bias brakes but the still had a servo either in the back or else where, just wondering why this is as some people dont seem to run servos with them
heres a lad that does
[/quote]
can some body explain? cheers
Jun 21, 2007 | 04:38 PM
servo with help you push the pedal
without will give you a leg like arnie
Jun 21, 2007 | 04:50 PM
I saw that artical and did wonder how a remote servo works. Servo is a total must for a road car.
Jun 21, 2007 | 04:53 PM
my mate had bias brakes on his fiesta without a servo & suppose it was a wee bit hard but nothing crazy,
have you got your bias brakes installed yet gus?
Jun 21, 2007 | 05:33 PM
twin servos/1 front 1 back---- on the old school rally cars mate -off a beamer-stopped like nothing on earth as im sure some old timers wil agree ,
still got the old drawings from fords avo dept.
Jun 21, 2007 | 05:42 PM
yeah should be done now
mine was a bit of a mare as i have my master cylinders inside the cabin
these get in the way of steering coloum so i had a new one made
Jun 21, 2007 | 06:14 PM
who made it for you? can you get some pics mate as its a must now as ive welded up the holes under the battrey tray where the standard servo bolts on
Jun 21, 2007 | 06:24 PM
its still down at xworkss
his got a couple of bits to do for me, his just gotta get the engine in now so he can carry with his jobs
thats me pedal assembly thou
Jun 21, 2007 | 06:55 PM
fit the 1 thats bein fitted in cliffs/mine and simons car im sure the are a few pics of that floating round. its from rally design bout Ł200 needs the bulk head modding to make it fit
Jun 21, 2007 | 06:57 PM
Tony's brakes are out of this world on track, there isn't even 1mm of play in them. You have to press hard on them, would be a pain in traffic.
Jun 21, 2007 | 06:59 PM
have you got a link to it stuart? im a bit away from that yet but i would like to know how all this goes together
gus so how does that atatch to your bulkhead as i cant see no 'bracket' like bits sticking out, or do you fabricate your own?
Jun 21, 2007 | 07:05 PM
see the round tabs on the side
you make brackets coming of the bulkhead pointing towards rear of car and then use these tabs to mount up to it
so bolt goes throu top of bracket down throu tabs
probably not explained that very well
Jun 21, 2007 | 07:19 PM
oh i see, cheers
Jun 21, 2007 | 08:15 PM
Lovely looking set up Gus,pity I cant weld or I'd fab that peddle box into my car.Regards,Micky
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
