Fitting pistons on rods......How?
Old Sep 23, 2004 | 12:10 PM
zvhturbo's Avatar
zvhturbo
Default Fitting pistons on rods......How?
As above with regards to zetec pistons and rods.
Are they easy to do or is it a engine shop job?
I've been told they do it by heat treating them!!!
Matt.
Old Sep 23, 2004 | 12:11 PM
Ryan's Avatar
Ryan
heat and pressed in
engineers shop mate, as you dont want to damage the piston skirt.
only cost ya about Ł10
Old Sep 23, 2004 | 12:13 PM
zvhturbo's Avatar
zvhturbo
Per piston??
Thanks
Old Sep 23, 2004 | 12:14 PM
Ryan's Avatar
Ryan
no
for all of them.
Old Sep 23, 2004 | 12:22 PM
CabrioTurbo's Avatar
CabrioTurbo
cost me 15 quid to get my rods pistons put on my rods.. any engine/remanufacturing place will do it.
Old Sep 23, 2004 | 12:25 PM
zvhturbo's Avatar
zvhturbo
Can it be done with a couple of sockets in a vice to pust the gudgeon pins in and out?
Old Sep 23, 2004 | 12:28 PM
CabrioTurbo
do you need to take the old pistons off the rods? if you are trying to do this then it will require a hell of a lot of force to get the pin out!
Same goes for getting them in really.
Old Sep 23, 2004 | 12:35 PM
zvhturbo's Avatar
zvhturbo
I will be changing rods, so keeping old pistons.
Old Sep 23, 2004 | 02:03 PM
Rolls's Avatar
Rolls
when you find somewhere to do this, could you lemme know please matey- im gona be looking for somwhere to do all of the work on my 2l, ready for me to put together!
cheers!
Old Sep 23, 2004 | 02:05 PM
zvhturbo's Avatar
zvhturbo
Hello mate,
Try these people www.minister-power.com
They are ford Zetec and Duratec Specialists and are located in Chatham Just off Junction 3 of M2
Matt.
Old Sep 23, 2004 | 02:13 PM
Rolls's Avatar
Rolls
top stuff!
right click, save site- cheers matey!!
Old Sep 23, 2004 | 02:44 PM
Rick's Avatar
Rick
careful! very tricky job. Your not supposed to do it, as the pistons are usually scrap - its normally the rods u save - not the piston. It has to be done with heat, as little as possible, and NOT pressed on!
Old Sep 23, 2004 | 02:45 PM
zvhturbo's Avatar
zvhturbo
Oh god, i can see this all going tits up
I just spoke with a local engine shop who refused to do it as they always break the piston
Old Sep 23, 2004 | 02:46 PM
Rick's Avatar
Rick
told you!
I know Karl can do it
Old Sep 23, 2004 | 02:55 PM
Jon ERST S2's Avatar
Jon ERST S2
what pistons / rods are you going to use?
Old Sep 23, 2004 | 03:12 PM
zvhturbo's Avatar
zvhturbo
Farndon steel rods (fully floating small ends), Accralite pistons.
Problem is getting old con rods off.
Old Sep 23, 2004 | 03:16 PM
zvhturbo's Avatar
zvhturbo
Who reacons i can cut the small end off without damaging the gudgeon pin??
I bet i can
Old Sep 23, 2004 | 08:05 PM
DazC's Avatar
DazC
Buy new pistons you tight fisted twat!
Are the Accralites also fully floating to match the rods?
Old Sep 23, 2004 | 08:51 PM
Tim's Avatar
Tim
I have a 14lbs Sledge hammer and punch if thats anygood?
But seriously Karl may be the 1 to help you m8.
Old Sep 23, 2004 | 09:32 PM
zvhturbo's Avatar
zvhturbo
Not at Ł120 each
Yeah accralites are fully floating as well.
Old Sep 23, 2004 | 10:16 PM
EIL132's Avatar
EIL132
Don't even dream of trying this.
KW-rscos
11
Aug 31, 2015 01:51 PM
stu21t
14
Aug 26, 2015 07:06 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
ekjim
Aug 17, 2015 08:57 PM
Roosie
Aug 13, 2015 07:40 PM
