Burning oil :( Out of ideas...
Old Jun 19, 2007 | 04:28 PM
haz87's Avatar
haz87
Default Burning oil :( Out of ideas...
Right ive got a xr3i(mfi) and its blowing blue smoke out the back. Ive changed the valve stem seals twice and also done a compression test which came back as
Cyl 1 - 149
cyl 2 - 149
cyl 3 - 148
cyl 4- 150
so there all way within tollerances(they were done when the engine was warm btw)
Any other ideas?
Old Jun 19, 2007 | 05:39 PM
Alvyn's Avatar
Alvyn
have you checked the engine breather isn't blocked?
compression may well be within a good tolerance but the oil scrapper rings last one on the pistons could be worn which is allowing oil to pass by!
Old Jun 19, 2007 | 05:43 PM
haz87's Avatar
haz87
Yup checked all the breathers out.
Some more background:
This all started after i changed the headgasket(tho ive done this a million times). However on this build i replaced ALL the valves, as i had one slightly bent and thought i may as well do the lot for peace of mind. However i never replaced any of the guides. Would this be cause for concern? I dont know how much CVH guides wear? There is minute play in each valve guide...
Old Jun 19, 2007 | 05:44 PM
As said, just because compression rings are good(?) it does not ALWAYS mean the oil control ones are.
I would also as said check the breather system.
Old Jun 20, 2007 | 01:21 PM
SafeChav's Avatar
SafeChav
I dont think those compressions are that good actually!! My turbo lump has higher compression than that (turbos being low compression in comparison to a N/A)
As for the comments on pistons rings..........a lot of people dont realise the second compression actually serves more as oil control than compression, and is usually an L shape to act as a scraper
Rsmat
89
Oct 12, 2015 07:50 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
