koni adj lifetime
Old Jun 18, 2007 | 10:43 PM
timturbo's Avatar
timturbo
Default koni adj lifetime
i have been missing around with my koni adj and have set them at a pretty firm rate as they were quite soft. they feel like coilovers now. does tightening them up increase the wear on them?
Old Jun 19, 2007 | 05:57 AM
JesseT's Avatar
JesseT
Bear in mind that the adjusting only affects the rebound and the bound is quite soft in comparison to start with.
Old Jun 19, 2007 | 01:45 PM
SafeChav's Avatar
SafeChav
While we are on the subject, is there any links to how adjustbale gas shocks work, always wondered.
tried looking on google but couldnt find much, you always seem to have something up your sleeve Jesse, amaze me again
Old Jun 19, 2007 | 02:30 PM
NUTS RuS's Avatar
NUTS RuS
Just a valve that controls the flow of the fluid (oil)
Old Jun 19, 2007 | 04:02 PM
SafeChav's Avatar
SafeChav
Ah i see, just wondered how the valve worked. Similar to a tap i suppose?
Was trying to find a cross sectional diagram, no such luck
Old Jun 19, 2007 | 04:13 PM
timturbo's Avatar
timturbo
so will it increase wear of the shocks then?
Old Jun 19, 2007 | 06:56 PM
Turbo-Beal's Avatar
Turbo-Beal
I would assume that if you are stiffing up the suspention you are limiting the amount of fluid that is diplaced in the shocks which would put more stress on the components. So i recon it could mak a diffrence. I thought that koni suspention came with a liftime gurantee anyway.
Old Jun 19, 2007 | 11:54 PM
NUTS RuS's Avatar
NUTS RuS
Not that much that you will notice.
This is how Bilstein control the damping Andy
Compression discs limit the fluid one way, and rebound discs monitor it the other way.
In an adjustable strut basically the valve apperture is the bit thats adjustable (open or closed as you say). This is fine when the oil stays at one temperature as it will give consistant bump/rebound characteristics. As the viscosity drops with heat it will alter things slightly. Thats why on the expensive struts you will see remote canisters and on competition Bilstein's you find fixed bump/rebound
Old Jun 20, 2007 | 01:10 PM
SafeChav's Avatar
SafeChav
Nice one Tony
but thats not an adjustable shock is it
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Topjoe9
Sep 12, 2015 09:50 AM
truffleshuffle
Sep 10, 2015 09:35 PM
cromb2555
Sep 3, 2015 04:28 PM
