Big Rear Brakes
I have 355s and 6 pots on the fron too but feel and improvement with the bias adjusted slighty.
Best way to test is remove abs fuse and brake hard in the wet.
all four wheels should lock at same time.
but it doesn't go out in the wet
its a 4x4 RALLY CAR YOU GIRL
the question is...
does a 330 mm brake on the rear makes sense?
i ve a 320 x 32 mm brake in the front from a gt3 porsche, and rear is stock, it breaks perfect on the ring, the front is even to hard, as the abs puts in all the time.... so it is senseless in my eyes to go that big and hard on the rear, if you don t really have 5xx horses and do one trackday after another....
don t understand me wrong, its looks absolutly brilliant but sense? :P
http://www.randbmotorsport.co.uk/sho...p?ProductID=40
There is no point what-so-ever going for the bigger 330mm discs with the standard calliper, as this kit uses the exact same bell as the 300mm kit, and the disc is just 30mm wider, which means that 30mm of the inner part of the disc is untouched by the pads (which looks shit
There is no need to run a bias valve on 2wd cars with this set-up, and in fact, I would not recommend putting too much braking at the rear on a 2wd car, as this can easily destablise the car at very high speeds if all four wheels lock up together
. I would personally prefer the rears to NOT lock up at the same time.
On a 4x4, you can put LOTS more braking to the rear and this won't happen, due to the wheels being linked by the 4wd system. However, if you have uprated callipers at the rear, I personally think it is a MUST to have a bias valve to ensure the braking can be adjusted to suit the car.
.There is no need to run a bias valve on 2wd cars with this set-up, and in fact, I would not recommend putting too much braking at the rear on a 2wd car, as this can easily destablise the car at very high speeds if all four wheels lock up together
. I would personally prefer the rears to NOT lock up at the same time. On a 4x4, you can put LOTS more braking to the rear and this won't happen, due to the wheels being linked by the 4wd system. However, if you have uprated callipers at the rear, I personally think it is a MUST to have a bias valve to ensure the braking can be adjusted to suit the car.
track.focus'd
Aug 12, 2015 05:53 PM
