ALS Problem
Old Sep 23, 2004 | 07:49 AM
Mattie's Avatar
Mattie
Default ALS Problem
Can anyone help ..........
A friend is having problems with his anti-lag set-up:-
With the anti-lag board installed in the P8 ECU, the car is very hard to start and when started, will only run on 2 cylinders, the anti-lag is working because boost is being generated, when switched on, but still only runs on 2
Spec is:-
4x4 Sierra Cosworth
P8 ECU with Collins Anti-Lag Board
Modified throttle elbow with WRC Idle Valve
Greys / T34
Can anyone please help
Old Sep 23, 2004 | 07:54 AM
Gavin E-Cos's Avatar
Gavin E-Cos
I was told that there is no warm up period built an anti lag chip. Mine starts first time but wont idle very well until warm.
Gav
Old Sep 23, 2004 | 08:16 AM
Mattie's Avatar
Mattie
cheers Gav
but theres definately more to it than that mate, two cylinders gone down with ALS board installed
Old Sep 23, 2004 | 08:32 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Default Re: ALS Problem
Where abouts are you? I can sort it if you like.
Regards
Jano
Old Sep 23, 2004 | 08:35 AM
Mattie's Avatar
Mattie
Nice 1 Jano
Do you have any idea what it could be?
Old Sep 23, 2004 | 08:42 AM
Gavin E-Cos
does it run on 4 when warm? or is it on 2 all the time.
Old Sep 23, 2004 | 08:52 AM
Mattie's Avatar
Mattie
from what he told me.....
all the time
but I will double check with him
He has been told by someone who has taken a look.......
weak spark!!!
Old Sep 23, 2004 | 08:55 AM
Ima-Racing500's Avatar
Ima-Racing500
When you switch anti lag OFF does it still run the same?
Versus_Creations
Ask me a question!
Nice 1 Jano
Without looking it would be silly to asume anything,
But when connected to a laptop and diagnostics equipment i can then see if it is within the map or another area i.e mechanical or electrical.
Regards
Jano
Old Sep 23, 2004 | 09:01 AM
Mattie's Avatar
Mattie
IMA.....
Yes mate, apparently, the only way to get it to run on 4 is to remove ALS board. How reliable are these ALS Boards?
Paul Hills originally mapped the car, the ALS set-up came off.
Jano.....
Will let him know
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
