Compression Ratio Question...
Old Jun 18, 2007 | 01:27 PM
JimmyBoy's Avatar
JimmyBoy
Default Compression Ratio Question...
I seen someone on here give a formula of some sort for it but I cant find it.
In a nutshell, if you have a zetec turbo (standard internals) and use a decompression plate to lower the compression ratio, how thick a plate should you go for? What sort of ratio would be a good target 7.8:1 ? 8.2:1 ?
Thanks.
Old Jun 18, 2007 | 09:49 PM
sas's Avatar
sas
should be good!
Try this - http://www.csgnetwork.com/compcalc.html
Simon.
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
