what causes a car to pull to left bad when letting off
Old Jun 17, 2007 | 09:29 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default what causes a car to pull to left bad when letting off
just bought a mk5 escort for runnabout when you go through 1st 2nd or 3rd and let go off the throttle the car pulls right over to the left badly when you put foot back down it goes back to right?
Old Jun 17, 2007 | 09:30 PM
Dicko&Vacant's Avatar
Dicko&Vacant
track rod end
mine does it when you accelerate it pulls to the left and when you let off it comes back over to the right
Sarah
Old Jun 17, 2007 | 09:43 PM
mechanic28's Avatar
mechanic28
lower arm bushes worn
Old Jun 17, 2007 | 09:49 PM
abdr500's Avatar
abdr500
if its a mk5 escort it would be the wish bones ther only Ł20 new each and that will replace all the ball joint in one go
Old Jun 17, 2007 | 09:53 PM
Ginge !'s Avatar
Ginge !
just finding my feet
have you tried to keep the steering wheel straight,,,,,,, thats the first thing i would check as when xrt-si used to complain about torque steer in his fiesta we discovered if he stopped jerking the wheel left and right that it reduced torque steer by 95%
Old Jun 17, 2007 | 09:54 PM
Ginge !'s Avatar
Ginge !
btw thats the CORRECT answer by a man who knows his onions
Old Jun 17, 2007 | 09:55 PM
abdr500's Avatar
abdr500
Ginge !
Old Jun 17, 2007 | 10:08 PM
zippyobrien's Avatar
zippyobrien
youll probly notice increased tyre were tot he inner wall and inner of the tyre
Old Jun 17, 2007 | 10:09 PM
Ginge !'s Avatar
Ginge !
mate if he can read that he wont need to ask the question
Old Jun 17, 2007 | 11:17 PM
silverfox999's Avatar
silverfox999
check to see if you have mismatched crappy cheng shing special tyres.
I had rear wheel steer from an old e30 from having a flippin mankey old remoulds, i changed them for new rubber and car drove in straight line....
Sounds like ends or bushes though..
Old Jun 18, 2007 | 07:04 AM
Bushes/joints .
Old Jun 18, 2007 | 07:34 AM
Spax's Avatar
Spax
My mate had this on his mk5 and was told it was the inner CV?
Old Jun 18, 2007 | 08:28 AM
wirralphil's Avatar
wirralphil
Old Jun 18, 2007 | 08:55 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
also could be fooked gearbox mount
Old Jun 18, 2007 | 12:10 PM
Roosie's Avatar
Roosie
both wishbones go replaced 2 years ago but i suppose like all thing depends on milage its done since
Old Jun 18, 2007 | 12:19 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
...and if the bushes used in the replaced wishbones were of shit quality!!! I managed to rip a spurious wishbone bush in a years worth of driving in my Bora!!!
Old Jun 18, 2007 | 01:17 PM
matts1's Avatar
matts1
just had this on a MK6, pulled to the right, replaced wishbones on both sides (did not look worn until removed.
Job done
Old Jun 18, 2007 | 01:20 PM
Roosie's Avatar
Roosie
ive just got 2 wishbones so ill change them tonight
Old Jun 18, 2007 | 01:52 PM
Good luck mate
i got a garage to do mine
Old Jun 18, 2007 | 02:03 PM
wirralphil's Avatar
wirralphil
Good luck mate
easy job only a few bolts.
Roosie's Avatar
Roosie
i done my mk6 ones and they were a peice of piss surely there the same
Old Jun 18, 2007 | 02:08 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Its play somewhere in the suspension or steering, but TBH it could be multiple things.
Could even be the shell is torn and moving about!
I only had a trolley jack @ the time so didnt want to chance it
Old Jun 18, 2007 | 02:09 PM
wirralphil's Avatar
wirralphil
same i think.
Archiejay
Aug 12, 2015 12:07 PM
Adam-M
22
Aug 10, 2015 10:46 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
